wanted xr650r front rim and spokes
4 replies to this topic
  • hourout
Posted January 02, 2006 - 05:54 PM
i cracked my rim at the seam on the last ride.. :applause: anyone know where i can get a new or used rim.. there is one on ebay from an xr650l.. i have a 2001 xr650r, are they compatible. thanks in advancel. :bonk:
  • Maddox101
Posted January 02, 2006 - 07:59 PM
I'm not sure if the one from the L will fit. But I do know that one from an XR400 will. I found one here from a fellow TT member. But ebay is definitly a good place to look as well. Good luck with your search.
  • Maladjusted_XR
Posted January 02, 2006 - 08:32 PM
If the "crack" is limited to the fabricated factory seam then you should be able to repair by welding. A competent welder can put it back together no problem. Ensure 100% weld penetration or welded from both sides and ground smooth.
If you have a crack outside the seam or metal fatigue with elongation (stretch) then I would definitely replace.
I have repaired rims by welding with separation at the seam previously with no further issues.
Hope this helps.
CJ
  • mackmack
Posted January 04, 2006 - 10:04 PM
I have an almost new xr 650r complete wheel (hub , rim, spokes laced up ) for $200.
  • hourout
Posted January 11, 2006 - 06:57 PM
could you e mail me a pic. damato@nac.net thanks in advance. later :applause:
