hot start nut removal ?
8 replies to this topic
  • 450high
Posted January 02, 2006 - 02:24 AM
Could someone please explain how to get the hot start nut ( carbi end ) of my wr 450 as the plastic one is buggered and i have a aliminium on the way.
Many thanks david.
  • simon@vic
Posted January 02, 2006 - 02:37 AM
i think they are called duck billed pliers. they are flat nosed pliers from snap-on.
  • MotoGoalie
Posted January 02, 2006 - 08:44 AM
Many thanks david.
Take the entire cable off the bike. It goes on and off at the lever end.
WhyTF do they put plastic nuts on these bikes? :applause:
  • Dan_Lorenze
Posted January 02, 2006 - 08:54 AM
I usually use a pair of needle nose to get it loosened up. After that my fingers can do the rest..
Now that were talking about it, I would like to replace the cable actuated HS lever with an old school (non remote) plunger type since I never use my HS circit... It's one less thing to take off the carb..... :applause: Now that the WRs are estart with the decompression cam the HS option isn't as critical as finding TDC like they way it used to be. I haven't used my HS ONCE since I've owned my bike (one year), I've got thousands of miles on it...
What do you guys think?????
  • simon@vic
Posted January 02, 2006 - 11:06 AM
^i never did. now i do all the time.
  • Dan_Lorenze
Posted January 02, 2006 - 02:03 PM
Why do you think that happends? I can remember when my 98's valves became out of spec the HS became mandatory. Once they were adjusted the HS wasn't needed. Hmmmm :applause:
  • dbailey223
Posted January 02, 2006 - 04:47 PM
Vice grips might also be the way to get out a mangled plastic nut. I gunked mine up on the first time taking it off and got the metal one.
  • 450high
Posted January 03, 2006 - 01:47 AM
Thanks all for the info. Dave
  • TARFELE
Posted January 03, 2006 - 06:11 AM
Speaking of nuts, My left one is abnormally, Oh, sorry different forum!
Anyway,
My hot start lever is realy stiff, I have never used it. Is it supposed to be smooth and can you pull it like a clutch lever?
