Tusk Clutch
6 replies to this topic
  • Xr650rhonda
Posted January 01, 2006 - 05:38 PM
Anyone have trouble using the Tusk Clutch? I put one in while changing my timing chain and installing a Hot Cam stage I. I have to adjust the clutch cable all the way out(both adjustments) to the max before feeling anything at the lever, when I put in the old friction disks everything is back to normal. Anyone else run into this?
  • don87xr600
Posted January 01, 2006 - 05:42 PM
Did you pre soak the discs in oil?
  • Xr650rhonda
Posted January 02, 2006 - 12:41 AM
Yes I did, I followed the manual step by step. The Tusk friction plates don't seem to seat in the basket like the stock ones (I received the right part number), this maybe due to more material on the tusk plates. I was prepared to adjust my cable, but I was thinking I should be bringing my adjusters in, rather the out? or do I have it backwards?
  • Shawn_Mc
Posted January 02, 2006 - 10:24 AM
Its the steels. They are slighty thicker. I ran into the same problem with a Barnett on my CR500. I put the OEM steels (aluminum) and it came back into spec.
As a side note, the aftermarket steels allowed the clutch to slip too...Those stamped things just dont work right.
  • Xr650rhonda
Posted January 02, 2006 - 11:47 AM
Thank You !!! :applause:
  • TimBrp
Posted January 02, 2006 - 04:18 PM
My Barnett dirt digger went in perfect and works perfect. Junk things on these bikes are the baskets and springs. Change them, and you're set.
  • Stinson
Posted January 02, 2006 - 07:28 PM
there are a few guys on KTMtalk running the tusk clutch and are having good luck with them. Cya Stinson
  • Hot  28 replies
  • 17 replies
  • 22 replies
  • Hot  60 replies
Honda XR650L 2016
  • 0 reviews
