Tire Pressure???
13 replies to this topic
  • phat_450f
Posted December 31, 2005 - 10:36 PM
Hey guys I have always wanted to know. What pressure's You run in your tires front and rear. I believe it about the same for all types of tires but I could be wrong.
  • 00YZ426FMRCD
Posted December 31, 2005 - 10:45 PM
I run 12-13 PSI (Front & Rear)
  • DPW
Posted January 01, 2006 - 06:39 AM
Same here closer to 12 usually.
  • RAMARION
Posted January 01, 2006 - 09:00 AM
Desert, rocky terrain...17-20
Desert, reg terain.......15-17
MX ......................... 11-14
  • 642MX
Posted January 01, 2006 - 09:05 AM
Me too. :applause:
  • phat_450f
thats what I thought. I will have to keep that in mind to raise the pressure up a tad when going to the desert. Thanks
  • kawirider
Posted January 01, 2006 - 10:39 AM
The owner of the shop I go to says to neve put more than 15-16 psi.
10 for sand
12 for mud, roots, average woods
15 for rocks
  • BergArabia
Posted January 01, 2006 - 12:14 PM
I run almost exclusively in sand and I am using about 13 lb front. I think the rear is 14 but that is a paddle tire.
  • bmeador
Posted January 01, 2006 - 12:16 PM
12! :applause: :bonk: :cry: :cry: :cry: :p :lol: :bonk: :bonk:
  • Yak
Posted January 01, 2006 - 01:44 PM
12-13 if you know you wont be hitting any rocks.
14-17 if I go trail riding in the rock gardens.
Some of the rocks around here are like hitting curbs. Anything lower and you really run the risk of a pinch flat. Yeah,.. you might loose I small amount of front end bite by running 17 but its better than getting a flat.
  • fowler175
Posted January 01, 2006 - 04:26 PM
I vary the pressure depending on the tire, and the terrain. Some tires ( like Maxxis ), have a very stiff sidewall, and work well with less pressure, while some other brands ( like Michelin ) work well with more pressure. I have always adjusted tire pressure by feel, and usually end up between 10-14psi.
  • djo269
Posted January 02, 2006 - 12:52 AM
I run usually between 16-18 psi front and rear. I ride mostly mx and weigh about 275 without gear. I case alot of jumps and was getting flats in front with lower pressures.
  • aford541
Posted January 02, 2006 - 02:26 AM
14 at both ends
  • flats00
Posted January 02, 2006 - 02:32 AM
Right at 14 front and rear. :applause:
  • 0 replies
  • 3 replies
  • Hot  113 replies
  • Hot  50 replies
