After Edelbrock install-choke lever
7 replies to this topic
  • TREADMARKS
Posted December 31, 2005 - 10:52 AM
Everyone that has went to the edelbrock carb-what do you do with your old choke lever and perch? :applause:
  • don87xr600
Posted December 31, 2005 - 01:28 PM
Huh?
  • husky123
Posted December 31, 2005 - 01:50 PM
Do you mean getting rid of your manual decomp lever? Not sure what you mean about that having to do with the Edelbrock though...
  • mgs781
Posted December 31, 2005 - 02:08 PM
You mean the choke level right?
Remove it and get a shorter bolt to hold the clutch level on.
MGS
  • TREADMARKS
Posted December 31, 2005 - 08:37 PM
Dang, I hate when that happens.
Yes-I meant what do you do with your old choke level :applause: I mean lever :bonk:
  • frankstr
Posted December 31, 2005 - 09:34 PM
Everyone that has went to the edelbrock carb-what do you do with your old choke lever and perch? :bonk:
Choke lever is still on the stock carb in a box, sitting on the shelf...
What perch are you talking about...uhhh.. :applause:
  • TREADMARKS
Posted January 01, 2006 - 07:31 AM
As is mine.
Even with the lever removed, a short bolt installed and the dual cable rubber boot removed, the perch still has the old choke cable mount on it. I would like to have the correct rubber boot in place as well.
Is there a different stock application or aftermarket perch, that will fit our bikes and has the clutch switch, mirror boss and rubber boot? :bonk:
  • frankstr
Posted January 01, 2006 - 07:50 AM
My bad, I relize now it must be a L thing ..
I ride a "R ".... :applause:
  • 4 replies
  • 22 replies
  • Hot  60 replies
  • 9 replies
  • Hot  35 replies
