XR650R Front End Vibration @ 70+ mph
11 replies to this topic
  • Maddox101
Posted December 31, 2005 - 10:13 AM
I'm getting a vibration/bounce at 70 mph and above on my 650R. It's not a head shake....but more of a fast up and down bouncing feel to it. It get's kinda uncomfortable at that speed. The bike is already set up with a Scott's damper and SRC fork brace. The previous owner had an aggressive DOT knobby on the bike. I switched to a less aggressive front tire and still have the concern. He also sprung the bike for a 240lb. rider. I'm about 190lb. Will the heavier springs be my concern or should I look at balancing the tire?
Thanks!
  • jim1234
Posted December 31, 2005 - 10:18 AM
Have you set the sag up? It will make a huge diff.
  • Maddox101
Posted December 31, 2005 - 10:30 AM
Thanks Jim1234. I'll check it today and give it a ride if this rain ever lets up!
  • PeterHively
Posted December 31, 2005 - 10:46 AM
You should balance the tire in any case.
Peter
  • Chas_M
Posted December 31, 2005 - 11:21 AM
You absolutely must balance both front and rear tires, especially if you are running single rimlocks. :applause:
  • roadcam
Posted December 31, 2005 - 11:53 AM
definitely sounds like an unbalanced tire
:applause:
  • 4Takt
Posted December 31, 2005 - 11:57 AM
check out this thread:
http://www.thumperta...ad.php?t=299056
  • mtrhd101
Posted December 31, 2005 - 12:45 PM
You should balance the wheel/tire assembly, adjust sag, also check the run-out on the rim, most are off some and high speed will exaggerate it.. Mine had a similar feel at about 75-85 mph. adjusting the spokes to correct run-out solved the problem.. :applause:
  • TREADMARKS
Posted December 31, 2005 - 01:08 PM
I had the same problem on a brand new pair of distanzias.
Took it back to the dealer and had it rebalanced-no help.
I finally put in these little guys-right here
One pack in the front, and two packs in the rear. My L has never ridden better. :applause:
  • HawkGT
Posted December 31, 2005 - 04:46 PM
That's an interesting product. I wonder if an ounce of sand would do the same thing??
  • Maddox101
Posted December 31, 2005 - 05:47 PM
Thanks for all the replies. I checked the sag today and its at 4 1/2" with rider weight. So that checks fine. I'll take the tire down to get balanced this week. If that doesn't work....I'll try the beads.
Thanks again and everyone have a great New Year!!!
  • HC
Posted January 02, 2006 - 08:49 PM
check your steering head bearings for wear. they lack grease fom the factory that lasts longer then a week.
  • Hot  29 replies
  • Hot  60 replies
  • 9 replies
  • Hot  35 replies
