Chain lenght DRZ 400 E and DRZ 400S
15 replies to this topic
  • okajic
Posted December 30, 2005 - 08:37 PM
:applause:
I’ve just bought a brand new Suzuki DRZ 400 S and found that the present sprocket ratio doesn’t suit my needs. Because I’ll be using the bike mostly for the off road trials with a plenty tight turns in the forest around my place.
Present sprocket ratio on DRZ 400 S is 44 rear and 15 front. I’d like to swap it with the 47 rear and 14 front which will be much better for my needs.
Unfortunately I’m not sure about the chain length! I mean I do not know whether or no I have to change a chain in order to swap sprockets from 44/15 to 47/14.???
I think Suzuki DRZ 400 S has the chain #520 with 112 clips and have no information about DRZ 400 E.
Please if somebody knows for sure give me a feedback.
many thanks,
Oliver Kajic
Croatia
  • Mal_B
Posted December 30, 2005 - 10:20 PM
The E has a 112 link chain as well. I've been told that I could use a 120 link chain without a problem though.
mal
  • Erik Marquez
Posted December 31, 2005 - 06:51 AM
As MAL said,, both DRZ's use a 112 link chain.. so swapping from 15/44 to 14/47 is a no change deal :applause:
I run 14/49 and 114 links.
120 links on stock sprockets might fit :bonk: , never tried it.. But if it does on a new chain,,, you'll be at the end of adjustment, the longest wheelbase, and no room to adjust as the chain stretches.
  • drzmike1
Posted December 31, 2005 - 07:41 AM
You can use 13,14, or 15 tooth front sprockets with a 47 rear using the original 112 link chain.
  • Learn2turn
Posted December 31, 2005 - 09:29 AM
what's the minimum links on a 14/47?
  • mazzuca21366
Posted May 07, 2008 - 11:02 AM
correct
  • Hatchet
Posted March 14, 2011 - 06:00 AM
I was researching this exact question and came across a really cool calculator
gearingcommander.com/
looks like I might be able to get away with using the same chain for both my sumo and my dirt setups:banana:
  • ptgarcia
Posted March 14, 2011 - 09:40 AM
A 110-link may fit but I doubt it. Most likely you'll need a 112-link.
  • Hatchet
Posted March 30, 2011 - 03:38 PM
NOPE. :cheers:
comes up about 1/8" short. stock S chain is NOT long enough for 14/47. this is an old chain too, so no way in hell a new one would fit.
  • ptgarcia
Posted March 30, 2011 - 03:50 PM
NOPE. :cheers:
Like I told you on ADVRider, you're chain isn't stock or has been shortened. The stock 112-link S chain easily accommodates 14/47 gearing. I'm running 15/47 on my stock 112-link S chain and its apparent 15/48 will work also. I suggest you go count the links and report back.
  • Erik Marquez
Posted March 30, 2011 - 03:58 PM
NOPE. :ride:
Ummm, yup,,it does :cheers:
Both the DRZ S and DRZ E use the same chain 112 links PN 27600-29F10-112.
The DRZ S comes with 15/44 gearing the DRZ E comes with 14/47 gearing .. the Chain fits BOTH sets of gearing as I listed.
If your not getting:thumbsup: it to fit, your doing something wrong :p
  • Hatchet
Posted March 31, 2011 - 06:41 PM
count the links.
well shit. you keep callin me out and keep being right. I hate it:moon:
well I suppose its time for a new chain anyways, this time 112 instead of 110.:cheers:
  • ptgarcia
Posted March 31, 2011 - 08:17 PM
well I suppose its time for a new chain anyways, this time 112 instead of 110.:ride:
Not trying to call you out, just want the correct information posted so others don't purchase the wrong stuff. :cheers:
  • Hatchet
Posted March 31, 2011 - 09:38 PM
No worries man, im just glad to have you know it all types around - thats the whole point of goin to these forums, to seek info from those who know better than I.
on that note, where do you buy your chains? I usually buy most my stuff from rockymountain. I would buy from thumpertalk but their store is the most confusing thing ive ever found on the internet. I guess I also need a chain breaker cause my old one got permanently "borrowed"
im still wondering why the hell the p.o. put a 110 link on..
  • ptgarcia
Posted March 31, 2011 - 09:52 PM
I usually buy wherever the deal is at the time, or if I need it quick run to my local store (Chaparral).
  • MotoChris521
Posted April 01, 2011 - 04:08 AM
'cause , maybe he was running 15/41. That's what I had to do.
Suzuki DR-Z400SM 2017 by Chris.GVS
  • Last review by MidnightMotard
  • On December 29, 2016
Desert SuperMoto by alpha_nett
  • Hot  60 replies
Found Dr-Z400 12 years old "Factory PACKED" by ezkhan
  • Hot  28 replies
Drz400s petcock question by JEEPNICK
  • Hot  27 replies
I think I am too stupid to install throttle cables... by razzledazzle
  • Hot  46 replies
