XR650L - to charge Battery - disconnect?
6 replies to this topic
  • bluerock5
Posted December 30, 2005 - 05:14 AM
In the manual it says you have to disconnect the battery to charge it - is that true or can you just clip the cables to the hooked up battery. Thanks
  • XR650L_Dave
Posted December 30, 2005 - 08:42 AM
Never disconnected mine, I use a small motorcycle charger/trickle charger.
D
  • Phuzzy McPhuzzface
Posted December 30, 2005 - 09:13 AM
Not sure. But I hooked up a Battery Tender pigtail up to mine, and routed/ziptied the cable under the battery box so I can conveniently connect it to the charger.
Not sure why you'd need to disconnect the battery for a trickle/maintenance charge.
  • LotsOfBikes
Posted December 31, 2005 - 11:48 PM
The higher voltage from a charger may damage electronic items on your bike, like your CDI unit. Many standard battery chargers have a sloppy DC current.
If you dont turn the ignition key on, you shouldn't have any problems.
It is just a precaution that the manual suggests.
  • mtrhd101
Posted January 01, 2006 - 01:59 AM
This is good information but I would dis-connect the negative cable to do anything more that a trickle charge.. Maintenance charge you can get away with, but if it's really low dis-connect the negative cable before charging.. Personally, I dis-connect, wouldn't you hate to buy a CDI unit because you were too lazy to take one bolt out ?? :applause:
  • rdefonce
Posted January 01, 2006 - 10:18 AM
I've never disconnected mine when charging. It's always worked fine. I have been using a Battery Tender, which is a low-rate charge. Max output is 1.25 amps, lower than that for maintenance levels.
  • Jayzonk
Posted January 01, 2006 - 09:31 PM
This is too funny. I just pulled my 650L battery out last week, and connected the charger tonight. I took it out because the manual recommends cleaning out the battery compartment every once in awhile. So I took it out, but there was no debris/missing paint. Still in good shape!
I removed mine so that I could charge it in a constant temperature environment. I'm not sure where you live, but I'm in Canada, so I didn't think it'd be so wise to be charging it at freezing/subfreezing temperatures, with pretty big temperature fluctuations.
