yamaha yz450f or ktm 525sx
6 replies to this topic
  • Tracy Allan
Posted December 30, 2005 - 05:12 AM
I'm going to buy a yz450f or a ktm 525sx, I want to use it for trail riding and riding wheelies. I want lots of fun power and a long lasting engine. Which would be better for the 2004 model ?
  • SureBlue
Posted December 30, 2005 - 08:48 AM
Welcome Tracy Allan.
2003 525 had a terrible suspension, especially forks, and a too light flywheel.
2004 was much better and they also went back to the heavier 2002 flywheel. The 525 power is smooth and very ridable. I have heard of some crank bearing issues on newer models, but it seems only pro riders who push the bike really hard have them. It is really a nice bike and ready for trails as it comes from factory, especially the EXC with electric start and lights.
It is 5-speed, has a juice clutch, Magura fatbars and a decent chain. It turns well but may give you occasional high speed headshake, therefore I recommend a steering damper.
The 450 Yamaha has a bullet proof engine, absolutely the most reliable of the big thumpers. You need a heavier flywheel on it for trails, at least you need to change a 50 tooth rear sprocket in order to reduce stalling issues since it is 4-speed and the 1st gear is a bit tall. But this will cost you on high speed.
Suspensionwise it is better than KTM, although I would recommend professional tuning/valving for your weight and riding style for both of the bikes, it will make a big difference!
It is very stable at speed, but may feel a bit top heavy. You can improve the handling and turning by setting the rear sag under 100 mm and raising the forks a little. It will still be stable in high speed.
Both bikes, like all thumpers, need regular low hour oil- and filterchanges. This is the best you can give them to keep them running for hours and hours.
Now, the traditional greeting:
:applause:
  • Triumphs
Posted December 30, 2005 - 09:02 AM
For Wheelies? Save yourself some money and get a used KX or CR500! And buy a spare rear fender right up front.
  • Tracy Allan
Posted December 30, 2005 - 10:25 AM
Looks like I should get a yz450. Now I just need to find a good deal on a 2004 model in Texas somewhere and buy it. Thanks!
  • bruntz505
Posted December 30, 2005 - 05:56 PM
YZ450F.There's a guy that had one on here for $2600,it was an '03.
  • bruntz505
Posted December 30, 2005 - 05:57 PM
He was in OK.
  • Tracy Allan
Posted December 30, 2005 - 07:36 PM
Thanks for the info !!
  • 0 replies
  • Hot  36 replies
  • 5 replies
Motocross
  • Hot  491 replies
