Tool Kit Recommendations
19 replies to this topic
  • Just_a_trail_rider
Posted December 29, 2005 - 08:50 PM
I always ride trails and desert, never on the track. I feel like I have been taking a big risk by riding off without anything to prepare me for accidents or failures while out on the trail.
I always have a toolbox in my truck, but I am setting up a toolkit to keep in a fender bag on the WR450 and could use some recommendations.
What do you guys recommend. All I know is what I use to do my oil changes.
Here's what's on my list so far. What should I add to it.
Wrenches 8, 10, 12 mm
Sockets 8, 10, 12, 18, 22, 27 mm
Ratchet and Breaker bar
Flat and Phillips screwdrivers
Extra Tube (what size????)
2 Tire irons
Tie Wraps
Electrical Tape
JB Weld
What else would you guys carry for the WR450? I am planning to enter an enduro soon and want to have everything that I need. But... I probably need these things regardless of entering the enduro.
Question: how do I inflate the tube after changing it? CO2?
Thanks for any advice.
  • 642MX
Posted December 29, 2005 - 09:31 PM
Sounds like you got it covered, yes CO2 is what you'll need to inflate the tube. Don't forget a cell phone, I always carry a phone with me.
  • bcs
Posted December 29, 2005 - 09:35 PM
If you've got an extra $50 to blow, get the motion pro aluminum tire irons that havea wrench on the other end. You buy one to fit the axle nut and one with a 12/13mm wrench for the nut on the valve stem/rim locks.
Also add a chain breaker and a spare master link. I also carry the small chain press tool that is needed to press on the side plate of the master link for your o-ring chain. Rocky Mtn. Cycle has one that's about $9.99 and is basically the same as the $20 motion pro version.
Carry a spare front tube--if you get a rear flat it can be run in the rear tire to get you through the day.
I like my mountain bike pump as an air supply--it never runs out of cartridges. In a race, I would use CO2.
I don't carry patches, but after the Malcolm Smith "no wimps" ride--where I got 2 flats in one day--now I want to. What brand / type of patches work well on a motorcycle tire?
  • clark4131
Posted December 29, 2005 - 09:39 PM
There was a thread a while back where we all listed pretty comprehensive kits. Do a little search and I'm sure you'll find it. Use my name and "baby-wipes" in the search criteria...don't ask...SC
  • David37
Posted December 29, 2005 - 09:42 PM
I carry the following items in my fannypack: an extra sparkplug in a plastic plug holder and sparkplug socket, vice grips pliers, multi-tool, mini T-handle and 1/4" drive sockets 6, 8, 10, 12, 6-in-1 screwdriver, matches, wire, 3-in-1 allen (bicycle type) metric wrench, misc. nuts and bolts.
You have a good list for tool pack but I would jettison the 3/8" drive ratchet and breaker bar, big sockets and replace it with a combination wrench that has a 22mm on one end and tire iron on the other end. I would go to 1/4" drive and 1/4" sockets. If you're going to carry an inner tube, carry a 21" tube it will fit your 21" and your 18" or 19" rim in a pinch. You can inflate your tube with either C02 or carry a mini bicycle pump. PM if you have any more questions.
  • SJMC_DON
Posted December 29, 2005 - 10:12 PM
cold beer usually gets me outta any situation. I try and carry as much as possible :applause:
  • Asgeir
Posted December 29, 2005 - 11:59 PM
Check out BlueRidgeRacing for the best complete solution :
www.blueridgeracing.com/
You can check out an review about those on :
http://www.dirtrider..._kit/index.html
  • Joe_dirtbiker
Posted December 30, 2005 - 11:02 AM
I just got a cute 'rider wrench' by Fredrette/Moose via dennis kirk. 27&13/16this on one end, 17 on the other. Works for the rear axle nut and the carb float bowl/jet change. A lot cheaper than the tire iron wrenches which I drooled over then frugalized away from. Vice grips/crescent wrench didn't offer enough clearance for the carb plug. Also got an 8/10/12 Y wrench which is small and amazingly effective.
Things not otherwise mentioned:
I carry a pill bottle of nuts& bolts
spare hose clamps on the handlebars
individual wrap handi wipes
TP
tow strap (it's for my buddies, not cause I do my own maintenance, honest!)
  • 642MX
Posted December 30, 2005 - 05:06 PM
I think the Blue Ridge people where at the Fall Ride at LL this year. I took a good look at them, and they seemed like a good deal.
  • Dan_Lorenze
Posted December 31, 2005 - 07:44 AM
Good links for sure... :applause:
  • byggd
Posted December 31, 2005 - 10:15 AM
WOW Big $$$$$ :applause:
http://www.blueridgeracing.com/
  • drewpeacock
Posted December 31, 2005 - 05:50 PM
Excellent quality rear fender bag that fits great and won't cover the tail light. http://www.dirt-bike...rdura_bags.html :applause:
  • Scott_Whitman
Posted January 05, 2006 - 03:07 PM
Try a tool kit from www.trailtoolz.com. Not as pricey and contains the basic tools that you might need.
  • Matty05
Posted January 05, 2006 - 03:11 PM
baby wipes a must! They are awesome for cleaning your face and grease and oil off stuff.
  • snowboardstylee
Posted January 05, 2006 - 04:43 PM
I also carry a few pair of Permatex blue heavy duty latex gloves in my pack (when i take my pack) they are small and weigh nothing and fit anywhere a lot better than getting super dirty and disposable and when you get up and riding you dont get greese on your glothes from wiping it off or inside your gloves.
a box of 50 pair was like $4 dollars at my local auto parts place(kragen)
  • Matty05
Posted January 05, 2006 - 05:03 PM
I always carry pepper and soap too.
pepper if I ever get a radiator fracture, and soap will last for ages in a slpit case.
  • gdm
Posted January 05, 2006 - 09:06 PM
Don't forget toilet paper, you'll be glad you have when the urge occurs! You can find small travel rolls at most drug stores.
  • taksx
Posted January 05, 2006 - 11:09 PM
All of this are great tips :bonk:
Personally I carry a tube of super duty silicon takes care of multiple things.
Here's my set. Buy a small fishing tackle box from your local sporting good's store and keep all the little items that would role around your bag in there.
Here's what its in it.
The bigger tools i carry in my pack.
This is a neat little trick for those with fender bags.
drill some slots in your fender(If you don't mind) mark the length of the hook, drill a multiple holes in a row, then just simply move the drill side to side till you have a slot.
Lost a bag early this season with about 100 bucks of tools and tire repair kit. If you do this make sure to bolt the sucker down...extra security :applause:
Eddie.
  • ARin
Posted January 05, 2006 - 11:17 PM
http://www.thumperta...ad.php?t=301552
and the tool kit from trail-toolz is a good bargain.
  • Punisher660
Posted January 06, 2006 - 08:04 AM
You cant forget the basics :bonk:
Duct Tape, Bailing Wire, and Vice Grips :applause:
