WR 426 spputter
3 replies to this topic
  • Derik Tate
Posted December 29, 2005 - 05:24 PM
I have a 02 WR 426, i have always had a small dead spot from idle. If i am at idle and crack the throttle fast it wants to stall. also at 1/2 throttle it has a sputter. My jetting is,
Needle is at #3
Screw out 1 3/4 turns
I am going to set needle at #4 and main up to 170. Am i going the right way? :applause:
I am at 1300 ft and usually ride when its between 30 and 80 degrees.
  • Matty05
Posted December 29, 2005 - 06:55 PM
sputter usually rich!
Your pilot looks lean, which would give a dead spot.
Check the jetting sticky, people have got their 426's singing for sure. They use different leak jets and stuff, well worth a try. Just pick out one that has the same conditions as you! Easy!
  • Derik Tate
Posted December 29, 2005 - 07:53 PM
i changed pilot to #45
main to #170
Started with 1 1/2 turn out on fuel screw and its to late to ride 2nite. But it sounded better no sputter. :applause:
  • Matty05
Posted December 29, 2005 - 07:55 PM
