Broken kickstarter guide in the crankcase - am I screwed?
6 replies to this topic
  • franktom
Posted December 29, 2005 - 06:26 AM
The guide in the crankcase for the kickstarter shaft broke. It broke about 75% of the guide off at the base. Since the guide is cast into the crankcase is there any way for this to be repaired or am I screwed?
  • bigboredbiker
Posted December 29, 2005 - 07:14 AM
If you mean the cast aluminium part, then I'm sorry to say that you wil have a lot of trouble welding it back in. The problem is that aluminium is porous, goes brittle with age/heat(work hardens) and also manages to absorb a fair amount of the engine oil. When you try to weld it, all that happens is that is spits, pops and generally makes a real mess. At best it might just hold for a short while, but the only real solution is a replacement....sorry. Any other thoughts from the other guys???
  • Bob East
Posted December 29, 2005 - 02:25 PM
According to my aluminum welding guru, another reason for the spitting
is that those cases are made of an aluminum/magnesium alloy and the
stuff is extremely difficult to weld. Also, if it ever catches fire, it can
be nearly impossible to extinguish.
Rgds,
Bob East
  • hodgkins
Posted December 29, 2005 - 02:30 PM
you might be able to have it bored out and put in a brass sleeve or you might get lucky and find a drill bushing the right size and have it pressed in.
  • bork
Posted December 30, 2005 - 06:39 AM
anyone else have this problem ? Any preventitive cures ? Will we all eventually have this break ?
  • Xr650rhonda
Posted December 30, 2005 - 07:07 AM
I fixed a big chuck of missing case just under my flywheel cover on my 1979 Xs1100f with JB weld. I shaped it with a dye grinding tool and even drilled it and tapped a thread. I have read posts of people using JB weld to fix holes in clutch covers and cracks in cases.
  • franktom
Posted December 30, 2005 - 07:50 AM
Thanks for the great ideas guys! However, I don't think there is enough surrounding material to "hold" a sleeve or bushing. The guide is load bearing and is about 1-1/2" deep so I don't think that JB Weld will have sufficient strength - given the extent of the damage. It looks like my only two options are: 1) find a replacement crankcase or 2) part the bike out and sell it piece by piece. :applause:
Washington
  • Hot  32 replies
  • Hot  29 replies
  • 9 replies
Honda XR650L 2016
  • 0 reviews
  • 22 replies
