wheel change
11 replies to this topic
  • xr-jorger
Posted December 28, 2005 - 05:21 PM
tire change should be a breeze with any luck
1hr later, 3bloody knuckles has me saying
I tried to save some money
I finally finished and its funny
the $12 saved has me felling like a schmuck :applause:
  • Mountain Road Madness
Posted December 28, 2005 - 05:29 PM
Sorry to hear about the bloody knuckles. I bought me a set of tire bars that makes the job a little easier. I put soapy water in a spray bottle for the tire to wheel contact. And a little trick I learned on TV. Baby powder on the tube. That really helps. :applause: :bonk: :cry:
  • don87xr600
Posted December 28, 2005 - 07:50 PM
1 hour for the first time might be a record, congrats! :applause:
  • PeterHively
Posted December 28, 2005 - 09:11 PM
Practice makes perfect!
Technique is everything, the key is keep the tire bead in the drop center of the rim. Easier said than done, I know. Especially with a super heavy duty tube, it can be a bear. Lubing the bead and powdering the tube do help. But not only did you save a few bucks, you are gonna be happy to have had the practice when you need to do it on the side of the trail sometime.
Peter
  • Husky_Forever
Posted December 28, 2005 - 11:37 PM
Sprocket side down will help your hands cut free and keep you from decades later looking at the scars from sprockets on your knuckles. :applause: Steny
  • georgiajim
Posted December 29, 2005 - 05:21 AM
interesting to hear how much trouble people have with tires.. My first time installing tires (S12 front and rear) was extremely easy. Used two tire irons and was done in probably 30 minutes (not including taking the rims off of the bike). However, I am convinced it was due to an added step. Before I attempted to put the new tires on, I put them in the shower with the hot water wide open for about 15 minutes while I watched TV and drank a couple three beers.
  • gimgim
Posted December 29, 2005 - 01:09 PM
I am going to have the same problem soon. Any suggested tire irons?
(online source preferred)
Thanks
  • Bob East
Posted December 29, 2005 - 02:19 PM
I definitely think that it was the three beers that lubed the process!!
Bob East
  • whitcher
Posted December 29, 2005 - 09:20 PM
Reminds me of putting old style clinchers on a really old Indian (1916). Had some "Non-Skid" OEM tires of similar vintage. To get them on the rim, you heated them up with a torch until they started smoking! Then they slid right on. Not much traction, but they never wore out!
Those were the days... Isn't technology wonderful?
  • char700
Posted December 29, 2005 - 09:44 PM
wow i guess im going to consider myself lucky my 1st tire change took about an hour but no bloody knuckles & i didnt swear. very lucky it was a heavy duty tube wraped with my old tube in a tire loaded with 1/4 bolts. dont ask
  • D36 Transplant
Posted December 30, 2005 - 09:36 AM
Making or buying a tire board helps too....a piece of plywood with a rod sticking up through the center works. This is key when I am changing a Foam / Mousse Tube. Once I get the tire bead broke off of the rim on both sides, I will spray a little soapy water between the bead and the tire. While all this is going on, the new tire is sitting out in the sun or next to a stove, warming up. I will then take the warm tire, spray more soapy water on the bead and toss some baby powder on the tube. I will put one side of the tire on the rim, insert the tube and start working the last side of the tire down. Once it is on, I will center the valve stem and air it up and seat the beads. Then I will let the air out, to relax the tube inside the tire and air it back up. I will usually put 40 or so pounds in it and watch it for a few minutes. If it isn't leaking, I will set the tire pressure and stick it back on the bike. Even if you have changed a lot of tires, there are times you find yourself yelling and cussing it.
  • Max Power
Posted December 30, 2005 - 11:32 AM
Good thread HERE
Being able to change a tire or fix a flat can be a life saver.
  • Hot  35 replies
Honda XR650L 2016
  • 0 reviews
  • 9 replies
Washington
  • Hot  32 replies
Fell Off Trailer by usafxr
  • Hot  43 replies
