Big Bars on my '06 WR450
7 replies to this topic
  • DWS450
Posted December 27, 2005 - 07:09 PM
Need some help / suggestions. I want to upgrade to the 1 1/8" bars, but I don't want to use the adapters. I'm sure they are safe, but I don't like the look and I don't need the additional rise.
Since the '06 OEM clamps are removeable, I'm thinking there should be a direct replacemet upgrade for the larger bars... However, I have not been able to find any.
Has anybody used, or seen anything that will work? As always, pictures, price & a link would be greatly appreciated.
  • 04_CRF250X
Posted December 27, 2005 - 07:18 PM
Do u want the fat bar mounts that mount on? if so renthal makes a pretty trick set.
Heres a link............
  • DWS450
Posted December 27, 2005 - 07:30 PM
Yes... This is what I'm looking for. Thanks!!! However, the application chart doesn't show the '06 450. I guess I'll need to place a call to Renthal. :applause: Thanks again.
  • clark4131
Posted December 27, 2005 - 07:35 PM
Pro taper makes the same thing in a universal kit that works for everything but a KTM...SC
  • DWS450
Posted December 27, 2005 - 07:57 PM
Thanks! I saw those, but they are listed as "for rubber mounted bars". Sounds like I'll be calling both Renthal & ProTaper tomorrow.
  • bomax
Posted December 27, 2005 - 09:55 PM
this is what i have on my 06 tapers(fatbar)with billet clamps.easy install.
  • sandman76513
Posted December 28, 2005 - 05:13 AM
You can order the upper and lower bar clamps for a 2005 YZ-F from your Yamaha dealer and bolt them right in, you can re-use the same 4 bolts for the top clamp and the same nuts for the bottom clamp....that's what I did when I switched over to the 1-1/8 bars.
  • sandman76513
Posted December 28, 2005 - 05:25 AM
Here are the parts numbers:
5XC-23441-90-00 Holder handle upper, order 2 each
5XC-23442-90-00 Holder handle lower, order 2 each
