Will "Mini" bend bars fit?
6 replies to this topic
  • Dutch
Posted December 27, 2005 - 05:47 PM
Is the distance between the clamps on mini's the same as the WR?
  • Matty05
Posted December 27, 2005 - 05:59 PM
Buy some new ones man, don't pinch your son's when he is at school just to go for a ride! :applause:
Posted December 27, 2005 - 08:28 PM
I can tell you this...... I put a full size set of Pro Tapers (cut down) on my sons RM85 but the bike has a Pro Taper top clamp on it but it should be set for mini bars, so in short, I would say yes :applause:
Posted December 27, 2005 - 08:29 PM
Gots to ask why? :applause:
  • Dutch
Posted December 28, 2005 - 04:04 AM
I live up in Northern Michigan where we cut the handlebar down to 29” or so to fit between the trees. I see Protapers for mini’s start out that width and was thinking it would leave me more room for the clutch/brake not having to chop them up.
Posted December 28, 2005 - 09:48 AM
Yeah I know what you mean, same story up here in Western Washington and when I cut down my Pro tapers you start running into the tapered part of the bar with your perches.
Good Idea :applause:
  • mtrablue
Posted December 28, 2005 - 04:35 PM
some do, some don't. are you going to be using pro tapers on this bike? i run the standard 7/8 bars and have found that renthal lists it's bar dimensions, including the clamping area. i run the yz80 (not 85) renthal bar. it's pretty close to a CR high but is 29" wide and about 1/2" taller (depending on who's you compare them to).
