XR650L alternator/flywheel - fix or replace?
3 replies to this topic
  • whitcher
Posted December 27, 2005 - 11:16 AM
I didn't find any info on this after searching the forum, so I'll try a new post.
My 650L suffered damage to the right side case that also damaged the alternator/flywheel - bent up the tin flashing inside the flywheel so there is no clearance, also chipped the protective coating on the stator, but the insulation itself looks OK.
How critical is the gap between the stator and flywheel? Is it OK so long as it clears?
Can I touch up the coating on the stator and be OK?
These are expen$ive part$!!
Most XR Hondas seem to use a similar set up with the stator in an oil filled case. Someone must have had this happen?
Thanks!!!
  • Bob East
Posted December 27, 2005 - 09:29 PM
The clearance between the stator and the flywheel shouldn't make
much, if any, difference as long as it doesn't hit. The number of
magnetic lines of flux cutting the windings in the stator probably won't
change significantly and that's what counts. As for touching-up
the coating, well, I'm not competent to comment on that aspect
of your problem.
Good luck,
Bob East
  • don87xr600
Posted December 27, 2005 - 10:07 PM
Look up info on rewinding your stator and use the same kind of epoxy to recoat your stator.
  • whitcher
Posted December 29, 2005 - 08:33 AM
Thanks for the tips - help a bunch.
Bruce
Washington
  • Hot  32 replies
  • 17 replies
  • Hot  148 replies
  • Hot  35 replies
  • 22 replies
