Chain?
2 replies to this topic
  • marcusmoberg
Posted December 27, 2005 - 12:55 AM
[COLOR=Blue]I tried getting the chain off my wr400f so I can clean it and it would not come off!
I got the pin off but the joint will not come off.
I tried pliers and a flat head and a hammer but nothing would get the joint to pop off.
Does anybody have any suggestions for getting my chain off?[/COLOR] :applause:
  • tmckeown
Posted December 27, 2005 - 01:54 AM
Hi,
If you a O-ring chain usually after you take the clip of (or what ever it is in english) frontplate will be really tight. I use Patton Chain breaker ( http://www.chaparral...A13D186D7AF64D1 ) to push out both pins from the frontplate and then it will be easy to pull rear plate with 2 pins attached out :applause:
When I install that chainlink again I push that backplate with pins thru chain and put the frontplate on its place and push it deep enought with this: http://www.chaparral...A13D186D7AF64D1 and then put that "what ever" clip on its place.
Hopefully this was at least somehow helpful
Timo Mc
  • Indy_WR450
Posted December 27, 2005 - 05:20 AM
The pins are worn from rubbing against the chain guide. Time to replace the chain or at least the master. Just take a large slot head screwdriver and a dead blow hammer. Put the master on the rear sprocket and wedge the slot head between the O-rings on the back side. One or two hits with the hammer and the master will pop thru the chain bushings. :applause:
