WR400 Harescramble Gearing
7 replies to this topic
  • mikie
Posted December 26, 2005 - 02:39 PM
RIght now I'm stock. I notice 1st is rather low and the gap to second is fairly large IMO. I have a new setup ready to go on, but its stock upfront and -1 out back (49). Now this could do one of two things; 1) 1st will be taller & great for trails 2) 1st will be too tall for very technical hills/tight trails.
Should I,
a) Go stock up front 49 out back in hopes of getting 1st to be taller.
:applause: Use the 49 and go down one/two up front.
c) Use the stock front (14) and just sell/forget about the 49 and get a 51/52. or
d) Use the 14/49
So basically should I gear up and hope 1st isnt too high? Or just gear down and use 2nd - 5th for most everything?
  • bg10459
Posted December 26, 2005 - 03:09 PM
Not sure I can help you much with a recommendation, but if you just do the math you can see the difference with various gear combos. 1 tooth up front is equal to about 4 teeth in the back. For example, a 13/49 combo will result in a .2653 ratio, a 13/53 will result in .2652.
No gear combo will change the large 1st to 2nd gap; that's in the tranny.
  • mikie
Posted December 26, 2005 - 03:14 PM
Exactly. However for the type of riding I do, as described in the title, I'm looking for the best option for what I have to work with.
13/49 looks great on paper. But I wonder what its like out on the trails.
  • SJMC_DON
Posted December 26, 2005 - 08:32 PM
I've raced nothing but tight and technical harescrambles on both my 400 and 450, I've always ran 13/50, it will alllow you to ride almost anything in second gear using a little clutch as needed and keeping some quick acceleration on tap. Just my 2 cents :applause:
Good Luck :bonk:
  • 00YZ426FMRCD
Posted December 26, 2005 - 09:39 PM
Should I,
d) Use the 14/49
My recommendation is option C. Go with the Stock front - 14 and a 51 or 52 rear. I race harescrambles on my YZ426 and have found that a 14/52 is just right. I rarely need 1st gear and thus avoid the possibility of mis-shifting to neutral from 1st to 2nd. Your 400 is geared different but I would still go with a 51 or 52.
  • simon@vic
Posted December 27, 2005 - 12:50 AM
14/52 or 13/50
  • Indy_WR450
Posted December 27, 2005 - 05:24 AM
Ditto 13/50 is my favorite gearing for tight single track and for hill climbs makes second gear more usuable and first is still great for super steep technical sections! :applause:
  • mikie
Posted December 27, 2005 - 11:28 AM
Awesome, thanks for the replys.
