Extreme weather means extreme measures
28 replies to this topic
  • tmckeown
Posted December 25, 2005 - 12:51 AM
Hi,
Here in north we have problems with digital speedos because they freeze up if temperature goes below 0 centigrades. This means atleast 4 months of driving season here :bonk:
So here is my fix for that :cry:
You take a gripwarmer element
http://i31.photobuck...nx/88df2a58.jpg
cut it in half and resolder wire between halves
http://i31.photobuck...nx/IMG_0909.jpg
Then you get a box that will with fit your speedo and install modified gripwarmer in there with some insulation
http://i31.photobuck...nx/IMG_0911.jpg
Then install speedo on top of gripwarmer
http://i31.photobuck...nx/IMG_0912.jpg
Cut a hole on the lid and put on its place
http://i31.photobuck...nx/IMG_0913.jpg
Put lexan screen on the box and install it on the bike
http://i31.photobuck...nx/IMG_0914.jpg
Do all the wiring needed and put resistor between gripwarmer wire 5ohms/10W to cut some wattage of from it. Put a switch for it and voilá :cry:
No you can heat up the speedo when ever it start to freeze :applause:
Timo Mc
  • ARin
Posted December 25, 2005 - 01:39 AM
excellent!!!! good write up!.
  • simon@vic
Posted December 25, 2005 - 10:08 AM
:applause: :bonk: :cry: :cry:
  • tp3dxf
Posted December 25, 2005 - 11:03 AM
Your one tough dude to be riding around in that weather. If it gets into the 30's here in Cal I can't move let alone ride!
So is Conan O'Brian really a star in Finland?
  • tmckeown
Posted December 25, 2005 - 12:07 PM
Hi,
We go out with bikes as low as -25 celsius / -13 fahrenheit. I think we have -30 celsius /-22 fahrenheit limit to keep races :applause:
Conan a star Hmmm... let's put it this way that lot's of people watch his show but a star... nope
Timo Mc
  • SJMC_DON
Posted December 25, 2005 - 12:49 PM
You guys got an engine warmer? How do even start a bike at -13 F? I have a real hard time here at +20 F :applause:
What weight motor oil do you run at that temp?
  • tmckeown
Posted December 25, 2005 - 02:08 PM
Hi,
Castrol GPS 10-40W, you just have to cover radiators and use thermostat.
Timo Mc
  • baha
Posted December 25, 2005 - 03:43 PM
Thank You God for letting me be a Native of California-Whacked people and all. :applause: :bonk: :cry: :cry: :cry: :p
  • drewpeacock
Posted December 25, 2005 - 03:57 PM
What is the resistor for?
I put grip warmers on and don't think I used a resistor.
  • tmckeown
Posted December 25, 2005 - 11:24 PM
Hi,
Resistor is for lowering the wattage of that gripwarmer. I measured surface temperature on gripwarmer without resistor and it goes up to 60 celsius / 140 fahrenheit :applause: . So just keeping it safe and not from melting anything.
If you buy a gripwarmer set it has a resistor with it that you can use for the low setting.
Timo Mc
  • drewpeacock
Posted December 26, 2005 - 06:13 AM
Hi,
Resistor is for lowering the wattage of that gripwarmer. I measured surface temperature on gripwarmer without resistor and it goes up to 60 celsius / 140 fahrenheit :bonk: . So just keeping it safe and not from melting anything.
Timo Mc
Thank you Tim... :applause:
  • SpeedBlitz
Posted January 02, 2006 - 06:13 AM
Timo,
What thermostat do you use? I figured covering up the radiators would be sufficient. Do you have a picture of your setup?
Thanks,
SB
  • mtrablue
Posted January 02, 2006 - 08:30 AM
it allows you to have a high and low setting. some people wire it with the clutch side on high all the time because the bars pull a lot of the heat away. i use oury grips and with the high setting the grips get real soft!
  • Dan_Lorenze
Posted January 02, 2006 - 08:33 AM
Nice job Timo.... :applause:
  • tmckeown
Posted January 02, 2006 - 09:32 AM
Timo,
Thanks,
SB
Hi, sorry no pictures yet :applause: because I have not put a thermostat on my bike. But talked to my friends around and they said KTM EXC has the best suitable for it. I need to get and put mine in before feb when we start having iceroadracing competitions.
Timo Mc
  • SpeedBlitz
Posted January 03, 2006 - 10:08 AM
Timo Mc
Thanks Timo.
BTW, I'm very curious about European ice racing. The tire technology is quite different. Do you have some good links regarding Euro rules, or I guess in your case, the rules in Finland. Is this website a good reference?
http://www.iceroadracing.com/en/
Thanks
  • tmckeown
Posted January 03, 2006 - 10:58 AM
Thanks Timo.
Thanks
That is THE place when we talk about iceroadracing in Finland, most people ion that forums races. Best tyres over here you can find behind this link:
http://www.kisarenga...to.html#jaarata
Timo Mc
  • tmckeown
Posted January 03, 2006 - 11:02 AM
Did some driving today and here is the end result :applause:
http://www.bikepics....ictures/494452/
http://www.bikepics....ictures/494453/
http://www.bikepics....ictures/494454/
Timo Mc
  • SpeedBlitz
Posted January 04, 2006 - 06:28 AM
Nice pics Timo!!
  • Asgeir
Posted January 04, 2006 - 01:48 PM
Hi Timo
Nice pictures.
What HID light is you have there ?
Where do you buy those heated grips ?
You are buying those ice tires at a really good price.
Asgeir
