Cold weather starting ('05 WR450)
8 replies to this topic
  • TBone_Boston
Posted December 23, 2005 - 03:04 AM
I want to know if what I am experiencing is normal.
On real cold days (less than 35 F) its almost impossible to start my bike. EStart is useless and kicking it feels like a stairstepper.
Also when I engage the clutch and put it in gear the clutch doesnt seem to work. I can pull the bike backwards but when I push it forward the wheel stays locked up.
Can I assume the the oil is just thick as a brick and THATS why so much trouble? I end up rocking it back and forth until the clutch engages and I can push it forward (warm up the oil?) and then I can kick it over. So i'm wondeing is this normal? And am I hurting anything by forcing the clutch like that?
  • Indy_WR450
Posted December 23, 2005 - 04:23 AM
Get a 72 or 75 starter jet for cold days ( you will not need to turn the throttle at all during the starting cycle). The bike will e-start down to about 30 degrees without problems. Yes the cold clutch will grab. let the bike warm up for 2 or 3 minutes when it is that cold. Evaluate your clutch for issues only after riding it for a few minutes. :applause:
  • yam314
Posted December 23, 2005 - 07:18 AM
Indy i s right. I just installed a #72 starter jet in yesterday, and Man!, that bike fires right away. It used to take forever,and I would eventually have to kick it before the battery ran down.
  • mtrablue
Posted December 23, 2005 - 07:54 AM
also think about the oil you have in there. if you haven't already, change to some fresh 10w-30. you may have some guys up that way using even lighter.
  • John M62
Posted December 23, 2005 - 10:35 AM
Mine is hard to start also. I find if I kick it about four times with the ignition off and choke on, then turn it on and use the electric start, it fires up .
John
  • PumpkinHumper
Posted December 23, 2005 - 11:12 AM
Yamaha makes a cold weather formula motor oil. I use in the winter for my YZ400 and my kids TTR90. It is thiner than the normal oil and turn over easier when cold.
The starter jet makes a huge diff when starting. Listen to the wise indy...
  • TBone_Boston
Posted December 23, 2005 - 11:32 AM
I'll look into the new jetting first. I don't expect to ride much during the Winter but I do at least like to fire it up every week or so to keep the juices flowing.
Thanks again!
  • tmckeown
Posted December 23, 2005 - 11:37 AM
Hi,
My brother had the same problem. I changed slow jet to #48 and opened up fuel screw to 2 turns on his bike voilá :applause: He has stock exhaust so if you have something more opened up you might need even bigger slow jet.
Timo Mc
  • Moondogger
Posted December 23, 2005 - 09:23 PM
I had the same thing happen to me after my bike sat for a long time in the garage. The oil got thick and the clutch wasn't engaging. No harm done. After the bike warmed up, the clutch worked fine.
