2006 WR Speedo on a 2005 WR
30 replies to this topic
  • ARin
Posted December 26, 2005 - 07:37 PM
#21
id like the RPM guage if only to set my idle.
  • tmckeown
Posted December 27, 2005 - 12:08 AM
#22
Hey Timo Mc
Trailtech sounds like the way to go. Do you have a pic of it fitted?
PM me please. :applause:
Hi,
Yes I do but in my winter installation =)
http://www.thumperta...35&parentpage=2
Timo Mc
  • tmckeown
Posted December 27, 2005 - 12:10 AM
#23
Hi,
I have an enginehour counter under my seat whch shows hours when engine is off and rpm's when it is running. I use that to set up my idle if needed :applause:
Timo Mc
  • eductor
Posted December 30, 2005 - 12:12 PM
#24
Hi,
Timo Mc
--------------------- I am interested !!!!!!
--------------------- What type is it ?
--------------------- How did you connect it ?
--------------------- Where did you buy it ?
  • tmckeown
Posted December 30, 2005 - 12:35 PM
#25
Hi,
Here you have:
http://www.yamaha-mo...7/0/detail.aspx
You just wrap around wire on coil.
Timo Mc
  • bomax
Posted December 30, 2005 - 04:02 PM
#26
i swapped my 06 one out for the trail tech.mounst great to the stock 06 setup.
http://www.bcsportbi...2motard_114.jpg
http://www.bcsportbi...2motard_140.jpg
my only complaint is the wires from the computer itself to connectors is really fine so watch the routing of them.
Hey Timo Mc
  • tmckeown
Posted January 03, 2006 - 11:04 AM
#27
This how it looks on my bike:
http://www.bikepics....ictures/494455/
Timo Mc
  • eductor
Posted January 05, 2006 - 02:13 PM
#28
Timo Mc
I would like to see a picture on how you wraped the wire around the coil.
please..
If no picture is available then tell me, did you wrap it above or under the coils rubber seal ?
If under how did you route the wire through the rubber ?
Thanks !
  • RichBaker
Posted January 08, 2006 - 02:07 PM
#29
I pushed an awl thru the rubber seal and wrapped the wire around the lower portion that goes over the plug...it works great! I bought the Yamaha hour meter/tach.
  • tmckeown
Posted January 08, 2006 - 10:59 PM
#30
please..
Thanks !
Hi,
Above and just some elecrical tape to secure it on its place
Timo Mc
  • Punisher660
Posted January 09, 2006 - 10:08 AM
#31
I have the Trailtech Endurance on my YFZ, and it works well and looks great. There is one drawback to it though, when the sensor gets wet either after a wash or riding through a puddle, the water distorts the magnetic field that the sensor is reading and gives inaccurate readings. Its either that or I really had the YFZ upto 197 MPH :cry:
The tech support is absolutely first rate and that alone is a reason to buy from them - even if they are not as highly regarded as ICO or Watchdog, I will definitely buy from them again. I originally purchased the Trailtech with my Raptor - sold the Craptor for the YFZ - needed a mounting bracket for the YFZ (usually included when you specify model at time of purchase) Called trailtech support, they had it for me in 3 days at no cost. They did the same thing when I lost the magnetic bolt as well. :applause:
The feature I like on the new Lynx is a constant backlight.....its a pain to find it at night on the Endurance Computer when your flying down the trail :bonk:
