XR600R cam
3 replies to this topic
  • nate992v
Posted December 22, 2005 - 09:19 AM
I'm thinking about putting a new cam in the XR. Anyone have any ideas on which one/types are best? Don't want to go too crazy, as I plan on keeping it on 91 octane. Eventually, it'll get punched out to 628, so I'd like to keep it compatible with that. It already is jetted, snorkel removed, FMF pipe, and UNI air filter. Also, has anyone used the header wrap tape and gotten good results?
  • Bob East
Posted December 22, 2005 - 07:16 PM
Hi Nate,
Changing the cam shouldn't make any difference with respect to the
octane rating of the gas you run. That would change if you increased
the compression ratio. Just remember that if you have too much valve
overlap, your engine won't want to idle very well.
Good luck,
Bob East
  • nate992v
Posted December 23, 2005 - 09:17 AM
I worded that wrong. I meant not too crazy with the compression, or engine as a whole, which would necessitate the higher octane. Going with the Hot Cams stage one kit.
  • Bob East
Posted December 24, 2005 - 09:31 AM
Hi Nate,
Yes, that might necessitate the use of higher octane gas if the
compression ratio goes above what it currently is. I don't know
what the upper limit compression ratio is for an air-cooled engine
with respect to using 92 octane gas. I do know that a water
cooled engine can be successfully run at 10.5:1 because that's
what my Porsche 928's stock compression ratio is. It tends to
differ with air-cooled engines because the heads run hotter than
liquid cooled heads. For example, the airplane I used to own had
a compression ratio of 8.7:1 and was considered "High compression."
It wouldn't run on 87 octane gas. It was air cooled. The head
temperature during climb-out, at full power, would be at least 300° F.
Anyway, it sounds like you'll have a real handful once you finish
with the mods.
I, on the other hand, only want my bike for cruising the logging
roads, in the national forests, and a couple of ORV trails where there's
some excellent mule deer hunting. I'm too old for that hardcore
riding!!
Rgds,
Bob East
Fell Off Trailer by usafxr
  • Hot  43 replies
Washington
  • Hot  32 replies
  • Hot  28 replies
  • 3 replies
  • Hot  35 replies
