YZ470...High Compression or Not???
6 replies to this topic
  • Mighty_Whitey
Posted December 21, 2005 - 05:50 PM
Opinions are like......well.........anybody have some good solid opinions on what would be a better choice here.
I just got the cylinder done at Max Power and she is a 469cc now. I can go with a High Compression Wiseco 13:5:1 or a Standard 12:5:1 compression.
I use the bike to race a 30+ Vet series in Southern California and also trail ride. Probably put about 15 hours a week on it.
For fuel.......I do have a high octane (MotoSport 103) gas station pump right around the corner from me.
:applause:
Either way, she's still a 470! :bonk:
MW
  • 642MX
Posted December 21, 2005 - 06:18 PM
I have a 13.5:1 Wiseco, only a 426 though. I can tell a big difference in bottom end snap and mid range pull with the higher compression. It will run off pump gas without pinging, but I run race fuel anyway. Downsides are that its a hair harder to kick start, it makes the jetting a little picky, and in long hare scrambles it wears me out faster. I'd do it again. :applause:
  • Mighty_Whitey
Posted December 21, 2005 - 08:02 PM
Thanks for the reply. Just curious on the race gas, whuddya run?
  • kawirider
Posted December 21, 2005 - 09:07 PM
Get it dynoed and let us know how many ponies you got from boreing it out.
  • aford541
Posted December 21, 2005 - 09:20 PM
Have you tried that U-4 or the elf LMS fuel?
I use the elf LMS it works great, I think you should run the 12.5 piston and when you race use the oxygenated fuel and she should last longer.
Although my 05 likes a little richer jetting on the Oxy fuel.
  • CRFThumper
Posted December 22, 2005 - 05:22 AM
We like the u-4 as well!Burns clean,no hint of pinging,and smells sooooo good!
On the pricy side but you get what you pay for i guess.Just be sure you drain the carb after each use!!! :applause:
  • 642MX
Posted December 23, 2005 - 06:52 AM
Citgo 110 leaded. :applause:
