Exhaust for '06 XR650L?
3 replies to this topic
  • Motorrider
Posted December 19, 2005 - 07:52 PM
Has anyone found a slip on that will fit the '06 models? I purchased a WB E2 series for '01 thru '05, but the bolts aren't matching up! I find it hard to believe that Honda changed the "L" this year when it has been unchanged for years. :applause:
  • goblin127
Posted December 20, 2005 - 08:58 PM
Honda didn't change anything. How far off is it from stock? sometimes it may take loosening the entire system(header) to get the tail to fit . Or where it bolts to the rear turn sig. area you might have to do some tweaking. But I haven't heard of anyone not getting it to fit.
  • Manchu
Posted December 20, 2005 - 09:03 PM
Are you able to verify the part number on the WB to see if maybe they sent you wrong one?
  • Motorrider
Posted December 20, 2005 - 10:20 PM
Thanks guys, but it seems the mounting bolts are not right. The upper one that goes through the turn signal mount is too big in diameter on the smooth part of the shaft. If you've seen one, you might know what I mean. I was actually able to get the pipe on the header and into place, but could not secure it. I just don't know if I should send it back and try again, or try to fabricate something.
