Cam mod on the WR
5 replies to this topic
  • ford780
Posted December 19, 2005 - 03:54 PM
I was wandering if you can do the cam mod on it like you can do to the YFZ to get the YZ timing. i have the YFZ and am going to put in a WR-450 crank, rod and piston.
THANKS
  • Matty05
Posted December 19, 2005 - 03:56 PM
no, auto decomp prevents that.
  • Indy_WR450
Posted December 19, 2005 - 04:18 PM
Just buy a YZ450 exhaust cam. I have a buddy that is buying a YFZ450 exhaust cam for his YZ450 to make it half way between a WR and YZ timed! :applause:
  • Matty05
Posted December 19, 2005 - 04:54 PM
Did you mean YFZ?
  • Indy_WR450
Posted December 19, 2005 - 07:39 PM
Yes I meant YFZ450 cam. Fixed post thanks. :applause:
  • Punisher660
Posted February 09, 2006 - 05:59 PM
Just buy a YZ450 exhaust cam. I have a buddy that is buying a YFZ450 exhaust cam for his YZ450 to make it half way between a WR and YZ timed! :thumbsup:
Not recommended!
Do the cam mod (move it 1 tooth on the cam timing)
I have a few friends that moved to the YZ cam and it hurt starting ability, not to mention was not as big of a gain as simply changing the timing. Not trying to start anything, but have first hand experiance on this one. We lined up 2 quads (YZ camed) vs (YZ timed) - you wouldn't think it would be different, but it is - YZ timed pulled much harder on the top and maintained ease of starting. YZ camed had a little more bottom and fell off on the top + became finicky to start.
