Zip-Ty Screw
10 replies to this topic
  • Braz
Posted December 19, 2005 - 07:47 AM
Ok, I put my Zip-Ty in this weekend and when I back it out 1 1/2 turns it sure is loose. How you keep this thing in? I can tell right now that it will vibrate out the first time I go for a ride.
  • Indy_WR450
Posted December 19, 2005 - 08:26 AM
Send it back for a new one. It should be difficult to turn and feel stiff. Mine is very difficult to turn. The have had QC issues with thread cutting in the past with the ZipTy product. They should replace if for you but you will be out shipping and time. :applause:
  • Dan_Lorenze
Posted December 19, 2005 - 08:44 AM
Make sure that the spring is around the shaft of the screw! The spring is there to provide constant tension in the threads so that the screw won't vibrate loose.... You kit should include: screw,spring,sm oring and a small washer. (if it's like all other screw kits I've seen).
  • rich1167
Posted December 19, 2005 - 09:00 AM
My kit came with the screw and nothing els. But the instructions said to reuse the stock spring and washer. It works fine.
  • dbailey223
Posted December 19, 2005 - 10:14 AM
If a retailer sells a customer a screw that is defective, why should the customer have to pay to ship the defective item back to the retailer? The retailer should bear the cost. The customer bargained for a proper part and to have it shipped--not to pay for the retailer to try a few times to get it right!
  • das_sey
Posted December 19, 2005 - 10:50 AM
Good luck on getting a replacement. I had the same problem with my 03 WR450. I sent numerous emails to them and did not get a reply back at all. Went back to the stock screw. This is a company I will not do business with anymore.
  • Matty05
Posted December 19, 2005 - 03:55 PM
:applause: :bonk: :cry: :cry: :cry:
  • dbailey223
Posted December 19, 2005 - 05:40 PM
Yup, same here, and the screw fit tight as Indy described.
  • 642MX
Posted December 19, 2005 - 05:53 PM
Only in a perfect world! :applause:
  • 642MX
Posted December 19, 2005 - 05:56 PM
My screw is from MSR, but it looks just like a zip-ty. It fits pretty snug, but I have seen guys put a wire tie around the float bowl and screw to prevent it from turning back out.
  • old man dan
Posted December 19, 2005 - 05:57 PM
I got my fuel screw from the guys at Pro Moto Billett and it seems to be a really good quality part. It's brass not aluminum like most of the others and fits really well. Theres no way it will ever vibrate loose.
