Rekluse - whats it like?
24 replies to this topic
  • mtrdrms
Posted December 18, 2005 - 06:08 PM
SO I want to turn my 450 into a woods bike and I have heard that the rekluse or other slipper type clutches are phenominal. So whats it like to ride with one of these babies? Can someone describe the differences and is it really worth it?
  • biznet1
Posted December 18, 2005 - 07:10 PM
It's awesome.
1. If you are in too high of a gear, no problem. It clutches for you.
2. If you fall, it rarely goes dead because the clutch is engaged.
3. In turns it feathers the clutch perfectly.
4. On steep hills it give you the perfect amount of clutch.
5. If you get the left hand rear brake, it makes right hand turns easier.
downside:
You can't push start the bike.
All of your friends will want to ride it.
  • 642MX
Posted December 18, 2005 - 07:31 PM
It's awesome.
downside:
Exactly :applause: Its the best mod you can do. Visit rekluses site, they have plenty of info there click here
  • slopoke
Posted December 18, 2005 - 11:26 PM
is it like riding an xr50?
  • biznet1
Posted December 19, 2005 - 05:16 AM
Not at all. The XR50 is a semi auto, so there is no "clutching" effect. The rekluse engages and disengages the clutch for you. For example, though I don't recommend it, you can put the bike in 4 or (5th if you have one) and take off full throttle from a dead stop.
  • 426boy
Posted December 20, 2005 - 09:53 PM
how is that reckluse clutch for all around riding and just courious how it works in a holeshot type situation not nesecerily racing but just trying to get off the line quickly
  • mikie
Posted December 20, 2005 - 09:58 PM
do you shift without using the clutch perch?
  • biznet1
Posted December 20, 2005 - 10:17 PM
It's great for all around riding, particularly woods riding. For holeshots, it's important that there is NO bog in the throttle response. I was suprised at how well it works in the start. It helps you maintain traction and helps keep the front end down. If your third gear isn't too tall, you can even do third gear starts.
Yes. I don't use the perch, but I do have a left hand rear brake kit. It's great for right hand turns, but it does take some getting used to. Wait til you are about to take a jump and go for that non existent clutch lever and lock down the rear wheel!
  • mtrdrms
Posted December 21, 2005 - 05:47 AM
but can you use the clutch perch just like the rekluse wasnt there?
  • biznet1
Posted December 21, 2005 - 06:54 AM
The perch with the override, yes.
  • 00YZ426FMRCD
Posted December 21, 2005 - 08:34 AM
Question on this: I have a stock 00 426 and am eventually going to go with a Rekluse clutch once I have the $$'s. I know there is a fix for the 00 426 clutch by essentially going with new clutch parts from the 01 426. Here is my question:
Should I go ahead and do the 01 clutch Mod, then purchase and install the Rekluse or simply just purchase the Rekluse, a few of the 01 parts and install? The clutch on my 00 426 is a little grabby but once it warms up, it is fine. I just don't want to spend any more $$'s than I need to and definately don't want to purchase the same parts twice.
From what I have read on other posts and this one, the Rekluse is the way to go. (Especially for woods and trails) My clutch hand cramped up beyond belief at the last Hare Scramble I raced. I can only imagine what things would have been like with a Rekluse & can't wait to get one installed...
  • biznet1
Posted December 21, 2005 - 08:51 AM
You definately need to do the 01 mod first. Then buy the rekluse for the 01 instead of the 00. You should buy another basket too.
  • 426boy
Posted December 24, 2005 - 04:42 PM
just another question is it giong to make the bike any slower on a hillclimb or anything like that
  • biznet1
Posted December 24, 2005 - 06:05 PM
Definitely not. Probably faster, because it takes the human error out of the lever.
  • kawirider
Posted December 24, 2005 - 09:18 PM
What about when your just messing around doing donuts and such?
  • ncmountainman
Posted December 25, 2005 - 07:00 AM
it makes playin' around alot more fun because you can't look like an idiot when you stall it;because you can't. also the power is sooo much more controllable :applause:
  • mbwhitfi
Posted December 25, 2005 - 12:57 PM
How can you NOT stall?
I was riding a nasty rocky trails section thru a creek bed on my 99YZ400F I stalled it 3 times. I'd love to get rid of stalling the bike.
Also looking to trail mod my 400F, gear down, and add the E-line stator for crank weight, and maybe convert to WR exh cam timing.
Any advice or links???
  • ncmountainman
Posted December 25, 2005 - 01:31 PM
a properly jetted bike,with a correctly setup rekluse is just about impossible to stall. you can be wound up in 3rd gear and lock up the back brake without pulling the clutch lever and it won't stall. it's a centrifugal setup that works the clutch;stop and its disengaged,rev past the adjustable engagement point(about 22oo rpm on mine) and it feathers perfectly every time. :applause:
  • mbwhitfi
Posted December 25, 2005 - 01:56 PM
Does it disengauge at 2200?
No more 400 Rpm indecisive rock stawling on the YZF.
I do a lot of technical riding. Rocky creek crossings into technical offcamber rt turn hillclimbs and such.
YZF beats the XR in suspension engine brakes and power. Now if I can just make the combo useable.
Sounds like a Rekluse clutch might be part of my solution.
  • biznet1
Posted December 25, 2005 - 02:47 PM
You can adjust it to engage and disengage where you want (within reason). Anything beyond it's limits would not be very usable anyway.
  • Hot  36 replies
  • Hot  30 replies
  • 0 replies
  • Hot  50 replies
