Someone posted good results from 17-e after 19-e edelbrock needle change
3 replies to this topic
  • J_T
Posted December 18, 2005 - 03:40 PM
I'm speaking about the XR650R Edelbrock QS Carb.
At one time someone posted that they tried the 17-e needle that came with the edelbrock QS carb against the recommendation to use the carb out of the box with the 19-e needle and they were claiming better throttle response with the 17-e over 19-e needle. I would like to know how else the bike was set up?
I am happy with my bike but I ran across the extra needles and I have some down time and thought I'd try it out but thought I'd get a range to see if its something I could benifit from or just a waste?
If you are happy with the 17-e over the 19-e needle will you tell me how your bike is set up and your riding conditions?
Thank you
JT
  • J_T
Posted December 20, 2005 - 04:52 AM
I'll keep searching the past post
  • Agent2
Posted December 20, 2005 - 08:31 AM
For what it's worth, I believe the Quicksilvers are set up for 1500' elevation. Installed one on a XR400 - ran like crap in the California high desert - 3000' elevation. Luckily changing the needle is real easy (other than accessability), leaned it 1 size - the bike ran great. Loosen the intake & manifold clamps, twist the carb and change the needle, see what happens.
  • TREADMARKS
Posted December 20, 2005 - 08:51 AM
XR650L here with stage one cam, ported airbox and big tube header with W/B E series pipe.
16E needle, 3 clicks out from factory location, 1/2 turn out on accelerator pump bypass.
Edelbrock tech support told me the factory setup was for 1500 ft elevation that I may need to go 1 size up in the needle for sea level.
Also said he would send me a stiffer return spring due the throttle hanging up.
Would like to here from others as their setup and mods.
  • 17 replies
  • 4 replies
Washington
  • Hot  32 replies
Honda XR650L 2017
  • 0 reviews
Honda XR650L 2016
  • 0 reviews
