BK Mod
4 replies to this topic
  • dirttrack25
Posted December 14, 2005 - 01:01 PM
What tool are needed for BK mod what size drill bit an tap
  • Hick
Posted December 14, 2005 - 02:08 PM
Oooh.
I forget. Did you do a search.
I want to say I used a 5mm screw. I also used the same spring off the timing set screw (by the pulley).
So you need the drill (usually if you buy a single tap it will tell you what size drill bit), bit, tap, screw, and the spring.
Hope this helps.
  • mightymouse291
Posted December 14, 2005 - 07:00 PM
I used a 6-32 screw and tap. I think that it was a 3/8" drill bit I used. I don't quite remeber but I used calipers to find a bit smaller than the tap. But as you heard, the tap usually says what bit to use. Did it all in about 15 minutes.
  • dirttrack25
Posted December 15, 2005 - 08:26 AM
I did a search but I only found the tap size and screw size I didnt know what bit i should use. Hopefully when i buy the tap itll say what bit to use. Thanks
  • Satch0922
Posted December 15, 2005 - 05:28 PM
Detailed Procedure on the BK Mod
Pics of the BK Mod
1998 yz400f will not idle. by trolley
  • Hot  32 replies
  • 10 replies
  • On January 15, 2017
  • Hot  38 replies
