No Toil
27 replies to this topic
  • fatboyrv
Posted December 13, 2005 - 06:42 PM
has anybody ever heard of the no toil air filter on my 2001 yz 426 im running stock foam filter but i think i want to get the no toil foam are they any good ?
  • rasta
Posted December 13, 2005 - 07:02 PM
you will probably get alto of differnt opinions on this, i think no toil is the best cuz after you clean it , it comes out looking like it was never installed, plus i am pretty sure i felt a power gain. alot of shops sell the cleaner and the oil together with a paper you fill out and send to them and get a free filter.
  • 642MX
Posted December 13, 2005 - 07:28 PM
I think all filters work well......as long as they are cleaned regularly. I choose a UNI because you can separate the (2) filter elements for cleaning, and they are inexpensive too.
  • Matt96xr6
Posted December 13, 2005 - 07:46 PM
never had much luck with the unis and other twin foam filters. They tend to choke up the airflow.
But everyone has opinions. I like the notoil stuff cause it is so easy to clean. Just dont over oil the filter and keep the airbox clean.
  • Open_Class
Posted December 13, 2005 - 08:12 PM
I have been running No-Toil for several years now and love the stuff. Really cool group of people out of Marysville, CA.
Filters work great and and the oil and rim grease break down n the bio solution, leaving the filter looking like it was never used.
:applause: :ride: :p
  • kizzle426
Posted December 13, 2005 - 09:19 PM
Right on :applause:
  • MTRSPORTDAN
Me too. Love the notoil. I toss it in the washing machine 2-3 at a time.
  • David37
Posted December 13, 2005 - 09:55 PM
Another vote for No-Toil filter oil. I've had good luck with No-Toil air filters, I think they are as good as a Uni or a Twin Air filters.
  • racer8
Posted December 13, 2005 - 10:04 PM
I have three of the 400ex pod style filters.
They clean up great,excellent quality.
  • Reyndogg
Posted December 13, 2005 - 10:29 PM
i use no toil oil, cleaner, and grease...with twin air filters.
  • CV4
Posted December 14, 2005 - 06:55 AM
I've been running the No Toil air filters for 2 years and really like them. To me, they seem to hold up better/longer than anything else I've used.
  • tp3dxf
Posted December 14, 2005 - 11:14 PM
No Toil is a great product.
The No Toil filters are pretty good. You can get the filters so clean with the No Toil cleaner that I have found I used them a lot longer. I have got about 2 years out of my last two No Toil filters before the seams started to let go. Which I think is good.
I contacted Twin Air and they said it's ok to use No Toil on the Twin Air filters which I am doing now. They are easier to find then the No Toil filters.
  • Slowmotion426
Posted December 14, 2005 - 11:20 PM
I just use cheesecloth. I tossed the stock filter a long time ago. :applause:
  • nicholsd
Posted January 16, 2006 - 02:01 PM
I, too, have used NoToil for years and love how easy it is to clean the filter...comes out just about like new. But, I found one draw back with NoToil. If you don't change out your filter on a regular basis regardless even if there is very little dirt on the exposed surface of the filter the oil will "glue" itself to the air box mounting surface and the filter cage!!!! I know your saying I should ride more that way the filter will be cleaned more often. But, it has happened more than once that I have literally had to pry the filter/cage off the intack port of the box and then gently peel the filter off the cage perimeter frame. These filters have never had any other kind of foam oil, just NoToil. But, in my scenario the foam can stick so bad that small chunks of foam are left on the cage. So, therefore, change often.
  • Open_Class
Posted January 16, 2006 - 04:29 PM
I'm not sure why you having that problem. I have been a no-toil guy for 4 years and have never had that problem. I have even left a filter on for a several months before pulling it, with no issues. Bike sitting in garage during ACL rehab.
  • Pazzo_P
Posted January 16, 2006 - 06:45 PM
CAUTION, if you use the No-toil oil on OTHER FILTERS they tend to fall apart! (i.e.) UNI filters. I spoke w/UNI and was told their filter seam glue will not hold up do to the No-toil oil.
  • Open_Class
Posted January 16, 2006 - 07:16 PM
No-Toil works great with Twin-Air.
  • Yak
Posted January 16, 2006 - 07:23 PM
My UNI started to seperate too.. So who's fault is it? UNI or No-Toil? Either UNI uses crappy glue, or No-Toil has a problem with their formulation. Im sure both companies like pointing the finger rather than working together to actually solve the problem. :applause:
  • Open_Class
Posted January 16, 2006 - 07:44 PM
Use No-Toil as it is a bio friendly product and buy a known filter that works with it....like, oh....say....No-Toil filters. They work great, as do Twin Air filters.
No finger pointing, just common sense.
  • tark15
Posted January 17, 2006 - 08:32 AM
Thumbs up to No Tiol oil. I have used it with Uni, No Tiol, Twin Air, and the stock filter, and the stock filter was the only one that fell apart.
  • 10 replies
  • On January 15, 2017
