Carb Removal?
2 replies to this topic
  • TeamScream
Posted August 31, 2001 - 04:17 PM
What proceedure do you use to remove the carb, what is the easiest way out for you guys? I can do it....I am looking for the little secrets that you guys may have figured out after a dozen or so removals....wish to share?
  • John_in_Long_Beach
Posted August 31, 2001 - 07:11 PM
Why do you need to remove the carb? Is it for jetting, if so, I have been able to change all of the jets and needle without completely disconnecting the carb. Just scootching it around alot. Saves on having to disconnect all of the cabling and lines.
  • Taffy
Posted August 31, 2001 - 11:43 PM
i have both the engine holding plates on the left. this allows the carb to come right out and away from the machine.
