WHATS WRONG WITH MY BIKE? Revised for all you peop's that cant stand all caps
21 replies to this topic
  • 123jeffro23
Posted December 13, 2005 - 10:24 AM
Rode at Ocatillo. Rode up the big shell reef hill. Got ¾ way up and dropped bike somewhat softly. Got down to bottom of hill. Getting dark. Bike Making Weird Smell. Had to drive back since getting dark. All power still in Bike.
No residue on bike. Cleaned with enging brite.
Let Bike sit for a few weeks. Started up and immediately starting smoking from the the pipe that runs from top of motor to exhaust. Startled like normal. Didn’t ride but sounded same, revved up fine.
Brought to Yamaha. Still under warranty. They spend a ½ hour on it and told me my compression was low. I asked what is the normal compression? The said I don’t know. But mine was at 70. 24 hours later they called me back and said that it should be at 90.
Firtst they said they can get to it next week. Spend 3 hours tearing the top part of the motor our for it may be blown.
I didn’t run it out of oil or coolant. But the bike did seem to be hot from the white smoke rising up from the head pipe. I did have to fill it up with some oil and antifreeze the next morning but didn’t ride it.
Now its next week and I havnt given them the go ahead yet.
Yamaha dealer now says since I havnt got it tuned up ever that the valves could just be out of wack. That’s why the low compression reading. They want to do the full tune up with parts costing $220. Also, he said a drip down test to see why smoking?
I’ve had it almost for 2 years. I have the 2 year Western Warranty. The bike has full power as I remember on that day. I have taken care of the bike pretty well. Not ridden much. Whats your expert opinion? Am I getting the run around.
:applause:
  • MotoGoalie
Posted December 13, 2005 - 10:49 AM
Did you take it to Imperial valley cycle center?
  • 123jeffro23
Posted December 13, 2005 - 11:04 AM
No. Why?
  • MotoGoalie
Posted December 13, 2005 - 11:07 AM
No. Why?
those guys are clowns and this sounds like how they do work.
As for your bike. I have no idea what's going on with it. IF you trust your shop then that must be the fix. You could always take it to another shop for a 2nd opinion or ask advice on who to take it to in your local area.
  • SureBlue
Posted December 13, 2005 - 11:08 AM
Hi again Jeffro.
You told you had to add oil and antifreeze, so so it has been running hot, hasn't it?
White smoke and sweet smell = coolant is getting into cylinder. You have a blown head gasket or cracked cylinder/head.
Blue smoke and bad smell = oil is getting into cylinder. You have a broken piston ring/rings or your valve guides leak oil into cylinder.
Seems like you need to tear the top end down.
  • 123jeffro23
Posted December 13, 2005 - 11:18 AM
White smoke and sweet smell = coolant is getting into cylinder. You have a blown head gasket or cracked cylinder/head. :applause:
yeah thats the one. Sounds expensive...and not covered by warranty. How does my bike overheat and 20 other riders not on same ride?
  • 123jeffro23
Posted December 13, 2005 - 11:23 AM
Shop just called. blew out grommet which is between cylinder head and valve cover. thats why oil leaking. he called it the motorplug. other than that he will call me later for a prognosis. I wonder if the service guys read this stuff. because it seems to have gotten a lot less expensive since this post.
  • SureBlue
Posted December 13, 2005 - 11:44 AM
Sure, the decomp plug has blown out, consider yourself lucky, you only lost some oil (and the plug), now get a nice billet plug from TT Store.
http://thumpertalk.m...=13&Search.y=14
  • theclone
Posted December 13, 2005 - 03:41 PM
You say it is 2 years old right? and by "never had a tune up" do you mean that the valves have never been checked or adjusted? I hope not :applause: because that could be your problem.
  • SureBlue
Posted December 13, 2005 - 10:03 PM
Not unusual at all, he also said "not ridden much". I never had to adjust my '04 450 valves either. I also know several Yamaha riders who never even checked them.
  • Slowbiz
Posted December 14, 2005 - 08:53 AM
I've got an 01 426 and havent checked the valves on it either.
There isnt one symptom of any motor problems on my steed.
  • snowboardstylee
Posted December 14, 2005 - 09:15 AM
OK this makes me want to rush right out and get my valves adjusted.LOL..
Bro, jefro 23. improper jetting will make your bike run hot add in the deep sand in Ocotillo. the added stress and load on the motor. feel luckyyou only blew the de com plug. get a billet One . and have the top end rebuilt cleaned and adjust the valves. it will be cheaper in the long run than a new top end if it blows up or seizes.
i cant say enouhg times to people. Oil change oil change oil change oil change.
every ride if you can afford it if not every other ride.
  • 123jeffro23
Posted December 14, 2005 - 09:49 AM
Rebuild top end?
What do you think Yamaha should charge if i get that done now and put in the billet plug.
And what do you think it would cost if i just waited like you said not to since it'll be more expensive when it seizes?
Damn dirtbike riding is expensive.
  • 123jeffro23
Posted December 14, 2005 - 09:51 AM
they are going to adjust the valves and do their #point inspection. i usually know thats bullcrap for cars. 21pt inspection means pay me to do nothing.
  • SureBlue
Posted December 14, 2005 - 10:52 AM
Could not agree more.
Jeffro, when you get the solar treatment done to your bike at the dealer, ensure they at least change the cam chain and tensioner if your bike has ran over 60 hours.
  • 123jeffro23
Posted December 15, 2005 - 11:12 AM
Total for bike $375 including $125 parts. so that means not much for they replaced the gasket between the head and the valve cover (not covered by warranty). Gave me a new air filter, and adjusted the valves.
  • MotoGoalie
Posted December 15, 2005 - 11:25 AM
Jeffro, YOU HAVE got to learn to do your own work. You're gonna spend a fortune having a shop work on your bike.
  • snowboardstylee
Posted December 15, 2005 - 12:54 PM
Moto Goalie. . .
well i come from road race backgrond and working on those motors.
valves were pretty easy to adjust with shim under bucket designs. feeler gage + math skills + shims = easy vlave adjustment job. what is the design on 4 stroke dirt bike motors. I know im coming up due for one soon. dont know what the local race shop charges but im sure its not much considering there are not 16 or 20 vlaves anymore.
  • Fizz
Posted December 15, 2005 - 01:20 PM
with the "owners service manual" you dont even need the math skills ... :applause:
  • Pincushion
Posted December 15, 2005 - 01:31 PM
Jeffro,
Do you live near Long Beach? I'll be glad to give you a hand and show you a thing or two about these motors.
  • 10 replies
  • 0 replies
  • Hot  36 replies
  • On January 15, 2017
