03 450 Shift Problems
4 replies to this topic
  • cropduster
Posted December 12, 2005 - 07:08 AM
I'm new to the 450 after being out of mx for 20yrs, I've had the bike for two months and last race I couldn't shift to third or fourth under power. Just putting around and it will shift fine, under power on the track and no deal. The shop has ordered me a shift retention spring, anyone ever had this problem and if so was this the fix, thanks.
Posted December 12, 2005 - 07:40 AM
If you mean that you can't shift under power without the clutch, you shouldn't be able to, and you shouldn't try. But if you mean that you can't shift at high engine speeds, even with the clutch, that is another matter, usually a transmission bearing gone rough.
Can you be more specific in your description of the problem?
  • cropduster
Posted December 12, 2005 - 08:29 AM
It will not shift period, clutch or no clutch.
Posted December 12, 2005 - 09:09 AM
That's it wont shift with the engine speed up, right? But just putting around is OK?
If that is the case, then it sounds like a problem a guy I know with a 250F had with a bad mainshaft bearing. The best way to quickly check this would be to remove the clutch cover (run up the engine first to scavenge the sump and you won't loose any oil to speak of), and remove the plates from the clutch. Keep them in order, the ones on the ends are a different compound because they run on aluminum parts.
With the bike in neutral, the clutch boss (center hub) should feel smooth, free, and easy to turn by hand (you're directly turning the mainshaft by doing this). If you feel dragging resistance and/or roughness, you have a bad bearing as the cause of the problem.
What this causes is that the bad bearing puts enough of a load on the engaged gearset by itself at speed to make the undercut of the gear dogs hold it in gear against your efforts to shift.
  • cropduster
Posted December 12, 2005 - 12:31 PM
I think I found the problem. Switched boots right before the problem started, tried my old boots and shifts good. I am going to the track later and try both the old boots and the newer ones to do some testing.
  • Hot  47 replies
  • Hot  28 replies
  • Hot  38 replies
