Exhaust pipe dent repair?
Posted 11 December 2005 - 05:22 PM
Also, does anyone know if someone in the San Diego area offers this type of repair?
Posted 11 December 2005 - 05:26 PM
If it's only a dent, just take the header off the bike, fill it with water as much as you can, and stick it in the freezer over night. It should push the dent out. If it's not removed completely, repeat the process until the dent is pushed out.
Or.....
Cap both ends of the header, in one cap install a quick disconnect air fitting, heat the pipe up with a torch at the dent, then pressurize the pipe with air. Dent gone.
Posted 11 December 2005 - 05:35 PM
Have heard of the compressed air and heat but haven't tried it yet? How much pressure are you using & what kind of heat? Will a propane bottle be enough for a titanium pipe or I've heard people use MAP gas which i'm not familiar with. I have an air compressor but nothing to use for heat, what would you recommend?
Posted 11 December 2005 - 05:57 PM
Posted 11 December 2005 - 07:25 PM
Posted 11 December 2005 - 11:42 PM
Posted 12 December 2005 - 12:14 AM
Easy stuff once you decide to do it.
Posted 12 December 2005 - 06:06 AM
Posted 12 December 2005 - 06:19 AM
This procedure isn't the prettiest but is the only thing to do if your on the ground as much as i am. I smacked the header out about 4 times since i've had the bike 05 450 R
Posted 12 December 2005 - 01:31 PM
Posted 12 December 2005 - 02:13 PM
My bro has a radiator shop and he uses plugs and pressurizes radiators and other things, he only uses 10-20 lbs and sometimes the plugs fly, you dont want to be hit by them even at low pressures.
Posted 12 December 2005 - 03:01 PM
Posted 12 December 2005 - 03:22 PM
gchprime said:
Sounds like the most safe way to me.
Heating up somthing that is pressurized just sounds like an accident waiting to happen, yeah you might get away with it a couple of times but ya never know..
Posted 12 December 2005 - 03:42 PM
Posted 24 December 2005 - 12:16 PM
Posted 08 June 2008 - 07:34 AM
mine is about the size of my thumb print
Posted 08 June 2008 - 01:09 PM
It was from a point of a rock so it still has that punch mark but the dent around it is out.
Posted 08 June 2008 - 01:36 PM
Basically had the same thing on my stock pipe. I needed to do 5 applications, but the same end result. You can tell there was a dent, but the dent itself is gone. No capping, just put water in it, then placed it in the freezer so the water was where the dent was, and froze it. Dent was gone after 5 apps.
Posted 08 June 2008 - 04:54 PM
