Alligning the rear wheel
4 replies to this topic
  • Fordskin
Posted December 10, 2005 - 10:55 PM
I have measured 55mm from rim to swingarm each side but the alligning blocks tell me that the wheel is not straight :applause:
  • WayCrazy
Posted December 10, 2005 - 11:00 PM
I usually go by personal measurements instead of the blocks
  • Chas_M
Posted December 10, 2005 - 11:16 PM
I rely on "personal" measurements as well by carefully sighting down the tires, first front to back then back to front to make sure that both tires are in alignment. This is the same thing as the string technique and is better than relying on adjustment markers or even measuring from swingarm pivot to rear axle.
  • pbusanga
Posted December 14, 2005 - 04:40 AM
hi forgive my ignorance but what is the string system
  • Toolmaker
Posted December 14, 2005 - 08:32 AM
You tie a sting to something stationary and wrap it around the side of the rear tire (side wall ) , have the string parallel to to ground and as high up as you can without hitting anything but the tire
then bring it around until it just touches the front sidewall of the rear tire ,
then you will have a straight plane that should be lined up with your front tire.
adjust your rear tire until the sting runs down along the sidewalls of the front and rear tire , you will have to eyeball or measure the difference in width of the front and rear tire, the the best way is to go all the way around the bike so you can look at both sides of the front wheel.
I hope that makes sense , I have never done it on a bike but thats how we used to string a race car to see if everything was lined up right
  • Hot  148 replies
Fell Off Trailer by usafxr
  • Hot  43 replies
Honda XR650L 2016
  • 0 reviews
  • Hot  35 replies
  • 17 replies
