2004 WR450 gearing? Need more top end
8 replies to this topic
  • YamahaWR450FMike
Posted December 09, 2005 - 12:28 AM
What you guys running for a higher top speed? I ride mostly open desert, fast open dirtroads and in 5th gear at 50mph my engine is kinda reving. I already have a 49T on the back with the stock front countershaft sprocket. What are some numbers to get some more top speed out of my WR without the engine whining out at 70?
  • Dan_Lorenze
Posted December 09, 2005 - 01:00 AM
The easiest way to achieve this is to change out the counter sproket to a 15t.
  • YamahaWR450FMike
Posted December 09, 2005 - 01:41 AM
what size is the front stock countershaft sprocket? I thought is was a 15T?
  • kelldog
Posted December 09, 2005 - 06:06 AM
I have a 04 WR450 with a 15/48 sprocket combo it will do 100 MPH in the desert and still will climb anything it's the perfect set up
  • Dan_Lorenze
Posted December 09, 2005 - 06:59 AM
Mike, the bikes come with a 14.. The 15 is what you're looking for... :applause: I use one all the time...
  • MTRSPORTDAN
Posted December 09, 2005 - 08:15 AM
I just ordered a 15 tooth yesterday from the thumpertalk store. It was only $8.99. I went down two teeth in the rear to a 48 and still wasn't enough.
  • SJMC_DON
Posted December 09, 2005 - 11:55 AM
You will have to tool out (grind away) a little bit on your case saver to get the 15T up front, but your data is wrong......... my 04' will do 67mph with a 13/50 set up so you should be well above 50mph in 5th gear with a 14/48 set up. In the dessert I run a 15/50 and it suits me well but the majority of my riding is tight and technical single track so I use the 13T counter shaft most of the time.
Good Luck :applause:
  • YamahaWR450FMike
Posted December 09, 2005 - 01:03 PM
great thanks guys for the info. I'll go with the 15T and give that a try
  • OlaGB
Posted December 09, 2005 - 11:56 PM
My speedo (computer) stops showing my speed after 75mph with 14-50 on stock wheel dimensions.. But the engine revs more! My guess is about 90mph top speed.. I ran 15 - 50 before, and i would say it made 100+ then.. But i thought the 1. gear was a little heavy for wood trailing, in those very tight places..
But i think i will go for 15-50 again.. And 15-44 on my 17" `s..
