Red hot exhaust
26 replies to this topic
  • fred yale
Posted December 07, 2005 - 09:56 PM
When I start my 02 426F in the garage, I can see the exhaust glowing red hot by the head. Is this normal? Thanks, Fred
  • FASTFORWARDMX716
Posted December 07, 2005 - 10:11 PM
yes this is normal. the thin Ti header will glow like that until you ride it and cool it off. dont worry about it.
  • Fizz
Posted December 07, 2005 - 10:51 PM
has'nt it something to do with the ignition setting (to make it easier to start) when the gear is in neutral?
  • sirthumpalot
Posted December 08, 2005 - 04:12 AM
They should find every message with "glowing header" in the title and flag it as "newbie to 4-strokes". :applause: Just kidding. It's normal, don't sweat it. Nothing to do with special ignitions, etc.. 4-strokes have very hot exhaust and the metal that the header is made of glows easily. The combo gives you a glowing header. Enjoy!
  • Fizz
Posted December 08, 2005 - 04:47 AM
ok, guess i'm misinformed then ..
what do the neutral switch do? :applause:
  • sirthumpalot
Posted December 08, 2005 - 05:14 AM
I believe the neutral switch lowers the RPM that the rev limiter kicks in. I doubt it has anything at all to do with starting; your most critical starts typically occurr while it's in gear.
  • Fizz
Posted December 08, 2005 - 05:22 AM
that sounds reasonable .. :applause:
  • ian56
Posted December 08, 2005 - 07:23 AM
I don't believe the 426 comes stock with a titanium header pipe, but maybe you're leaving the choke on too long when it's cold.
Posted December 08, 2005 - 08:18 AM
The neutral switch on my 450 changes both the rev limit and remaps the ignition, and according to my strobe light, retards the timing at idle compared to when it's in gear. Sometimes I can hear the idle speed drop when I slide it into neutral due to the timing shift. They're probably more concerned with how it runs in gear at an idle than with how it starts, but whatever the case, the reasoning behind the idea is something we will likely never know for certain. They've also taken it out of the new ignition system, so they've figured out they can live without it.
The retarded timing at idle does contribute to the red pipe. I notice it takes longer to glow if I put the bike in gear.
  • Fizz
Posted December 08, 2005 - 08:27 AM
so was like ... half right?
  • sirthumpalot
Posted December 08, 2005 - 04:32 PM
OK you get 1/2 credit. :applause:
Retarded timing makes sense. 4-strokes are less likely to kick back at slow speeds (kick-start speeds) if the timing is retarded. Anyone remember trying to kickstart one of those old 4-strokes before electronic ignition? Kick to slow and WHAMO you have a foot that points strait up, or a leg with 2 knees. Anyway, I thought they solved the kickback issues by not allowing it to fire until the engine was spinning at least a certain speed. Very neat to know about the timing light, thanks for the info. :ride:
Posted December 08, 2005 - 04:56 PM
I do. Do you remember the British bikes with Lucas mags that had spark retard levers? I'll bet I got you with that one.
Sidebar: I warmed up the bike a little then stopped to get the rest of my gear ready. After a few minutes, I went to start it in gear and nearly got my foot broken, right through my Alpinestars! It was the hardest I've ever been whacked by any kick crank. I guess having a light flywheel lets the engine accelerate quickly in both directions, eh? Anyway, grayracer doesn't start his bike in gear anymore unless it's real warmed up. It only happened that once, but that was enough for me. :ride:
  • sirthumpalot
Posted December 08, 2005 - 05:03 PM
Indeed you win! :applause: :ride:
Posted December 08, 2005 - 05:14 PM
Really? What's the prize? : ohgoodyohgoody:
  • shigbie
Posted December 08, 2005 - 05:20 PM
No problems...I had a 01 426 and my first night race it totally freaked me out but it is normal. it can extend 5 to 6 inches from the jug
  • Shawn_Mc
Posted December 08, 2005 - 05:33 PM
Talk about getting kicked back...my brand new 83' XL600 kicked me back one day when I kicked at it half assed...it spit my leg back up into the handle bar hard enough to bend my dang bars....not to mention the bruise on my leg...
When I was a kid, I saw a drunk guy get kicked back by his Harley after the races one Friday night at Ascot. The thing spit his drunk ass off into a big puddle...pretty dang funny...
Posted December 09, 2005 - 08:00 AM
Those older bikes were different. They had a lot of force behind the crank when they kicked back, but with all the weight in the old crankshafts, it was a lot more of a quick push than a sharp blow. If you did right, it couldn't hurt you.
We had a Norton 19S in the shop for a while once. It was a 1000cc single cylinder built in the mid fifties to haul sidecars around, and was only sold in England and Europe. We used to park it next to the building for fun and let it toss us up over the side of the bike onto a work bench and see how high we could go, or over the bars and if we could land on our feet. It was like a gas powered trampoline. Crazy kids.
But when the 450 got me it was completely different; like being hit in the arch with a hammer, or just shot in the foot.
  • odlaw19
Posted December 09, 2005 - 10:27 PM
I would think the lower RPM in gear would be a result of the clutch dragging.....
I do agree that retarding the timing does lower the RPM but i think the clutch would be move of a factor.
Waldo
YZ426
  • fred yale
Posted December 12, 2005 - 12:03 PM
Thanks for the info! I just got this 426 and LOVE it! It handles perfect! Light enough in the front end to wheelie, and has great bottom end power! I've been riding a XR 600 Honda that is a real sled. All it's good for is blazing down the fire roads and hill climbs. At almost 300 lbs it's a pig. Somebody said that if there were no such thing as the Baja 1000 there would be no use for the XR 600 and 650! Later, Fred
Posted December 12, 2005 - 04:23 PM
Clutch drag is a factor in gear at a standstill. The RPM drop occurs on a shift to neutral, after which clutch drag ceases to factor into things, since the parts it drags against will then spin freely.
  • 9 replies
  • On January 15, 2017
  • Hot  47 replies
  • 0 replies
  • Hot  113 replies
