oh no!!!
11 replies to this topic
  • YZFSOCAL
Posted December 06, 2005 - 08:18 PM
oh no!!!!!!!!!!i just took off my clutch basket cover and a needle bearing popped out. it's not the needle bearing that's goes to the pushrod.. what are other bearing could it be?
  • BC61
Posted December 06, 2005 - 10:05 PM
The only needle bearings in the engine that I know of/found in manual are the pushrod, balancer and rod bearings. How big is the needle?
  • YZFSOCAL
Posted December 06, 2005 - 10:10 PM
it's smaller than te pushrod bearing..looks like about a 1/4 or a 5/16 bearing..
  • YZFSOCAL
Posted December 07, 2005 - 06:43 PM
any ideas?? looks like it was grinding around my clutch basket... here are some pics!!
here it is the way i found it
behind the clutch basket
damage to the clutch basket
the bearing looks to be a 1/4" smaller than the one that came out of the pushrod housing area..
  • MathProf
Posted December 07, 2005 - 07:14 PM
Take a look at the OEM exploded view
http://oem.thumperta...450Fclutch.aspx
look at other pics to find your vearing.
  • 2000yzf426
Posted December 07, 2005 - 07:31 PM
Just a shot in the dark but could it be #26 on this picture
http://parts.motorsp...1948,2,88423976 but then there would also have to be pieces of a spring and rubber
  • YZFSOCAL
Posted December 07, 2005 - 07:41 PM
thanks!!good call! i think that's it.. time to start tearing down some more... i'll let you guys know! there was no spring but that doesn't mean thats not it!!
  • kawirider
Posted December 07, 2005 - 08:08 PM
Maybe I am weird, but I think the inside of a mx thumpers motor is so interesting.
  • YZFSOCAL
Posted December 07, 2005 - 08:52 PM
ok guys are you ready for this?? i am in the process of replacing the head because of wear. the valves and everything were fine but i noticed the end of my exhaust cam cap was cracked. well i didn't notice before but the ball bearing at the end of that cap popped out and went through the motor and ended up lodged in the clutch basket... what are the odds. the inside of the motor looks pretty good. i have to replace one gear but that's it.. these fourstrokes are interesting!!! thanks for all your help guys. i was about to take it to a shop but when you guys responded i decided just to go for it!! thanks again!!
  • sirthumpalot
Posted December 08, 2005 - 04:10 AM
You have great luck that didn't find its way between some other parts! Good find and good luck with the rebuild. Go buy yourself a lotto ticket while you're waiting for your parts to come in. :applause:
  • ncmountainman
Posted December 08, 2005 - 06:06 AM
i never realized there was a ball bearing involved with cam removal? is it inside the cap for a oil check,and can only get out if broken?
  • BC61
Posted December 08, 2005 - 06:44 AM
:applause: ..... the pic shows a ball bearing not a needle bearing..... :ride:
  • 10 replies
Motocross
  • Hot  491 replies
  • Hot  47 replies
