NiteRider Off Road lights
9 replies to this topic
  • mexihonkey
Posted December 06, 2005 - 09:41 AM
Sorry, this isn't XR specific, but figured this is the forum for desert racers.
Anyone use or have seen the new NiteRider off road bike lights. The helmet lights look great but not sure if the bike lights are bright enough for 5th gear.
Thanks
  • BajaBoundMoto
Posted December 06, 2005 - 03:05 PM
Not good for 5th (IMO).
Best bet is to make your bike have the best light possible for your budget. Even the $60 Baja Designs upgrade is sweet.
  • Naru
Posted December 06, 2005 - 04:18 PM
I actually just picked up their new Hellfire HID kit. Can't say anything about the halogen version of it, but the HID version in conjunction with a 55 watt bulb is fine in top gear slamming through whoops. It would definately help to have their helmet system, but without it it's not bad. However, I'm still working on hard-wiring the system into the bike; the HID's need a battery to generate consistently clean power for them, so I'm trying to find a compact battery I can shove under the seat. Only place I have been able to find is Four Strokes Only, and I'll never deal with them again. :applause:
On a side note, I called up their tech support to inquire about their water resistance. NiteRider said that in light rain I will be OK, and in a heavy downpour I will *probably* be OK as long as I don't turn the switch on and off too much. As for falling in a stream or the sort, expect to be out roughly $120 per bulb and/or $40 per ballast, which ain't cheap.
  • Kritter
Posted December 06, 2005 - 08:53 PM
I use the light and motion arc HID for mountain biking..great light and I believe it is submersible but I could be wrong also comes with helmet and bar mount.
  • mexihonkey
Posted December 06, 2005 - 09:27 PM
That's my problem too. It's going on a crf450r - so no battery. Their battery seems nice but with only a 2hr run time with all the lights on is a little too short. I don't know anything about electrical, but why can't you use some kind of rectifer to run the lights straight from the stator?
  • Kritter
Posted December 06, 2005 - 09:51 PM
battery technology is insane...
I use a NiMh with my HID and get 3.5 hours, with the li ion that is a bit smaller and 100 bucks more it gets 4.5 and with the big li ion batter that is 200 bucks more it goes well over 5 hours.
There is an HID light called an edison that is used by top dog mtb 24hr racers that will last 10 hours on a charge
  • Naru
Posted December 07, 2005 - 11:30 AM
That's what I had thought initially (my electrical skills are definately lacking), and the tech guy at NiteRider said it should be OK. However, when I called up Ricky Stator for one of their HD rectifier/regulator units to replace the stocker, he took the time to explain to me how the voltage will not be constant at lower RPMs and will usually be ~9-10 volts for moderate riding, so I needed a battery to generate a consistent 12 volts with no spikes. So, I've found a set of 8 AA batteries wired up together like an RC car battery that are rechargable and run at 12 volt, but not sure if they will work for the HID. So, I'm going to try them out now so I can take advantage of NiteRider's 1 year garauntee if things go south (the tech said their warranty would cover such a situation :applause: ). I'll report back if things go well, or don't for that matter.
  • mikekay
Posted December 07, 2005 - 02:14 PM
my XR650 rallye bike has both HID and halogen lights on seperate phases. both DC and AC wiring. So i can run the halogen straight off the stator if the battery pack dies.
i have the baja designs battery pack under the seat-and a back up on the front fairing (plug and play backup).
no reason you cant do the same with the CRF450. You are limited to the wattage you can get out--but for just HID's you should be fine.
Baja Designs can do it for you. Cycoactive also knows how. Its not hard to set up--lots of guys do it.
  • Naru
Posted December 07, 2005 - 08:22 PM
Mike, which battery pack are you talking about from BD? Thanks.
  • mexihonkey
Posted December 08, 2005 - 12:38 PM
That sounds like a great idea. Thanks, I'll look into that.
  • 17 replies
Honda XR650L 2016
  • 0 reviews
  • Hot  186 replies
  • 4 replies
  • Hot  29 replies
