650R skidplate
6 replies to this topic
  • XR4DEZ
Posted December 05, 2005 - 05:55 PM
Does your skidplate allow you to take off your mag cover for a valve adjustment, if so what brand do you have? My Moose plate has to be removed to take off the mag cover and that's too big a pain.Thanx
  • Mikie1
Posted December 05, 2005 - 06:40 PM
You don't need to take off the mag cover for a valve adjustment- just the allen-head plug. You can see the F and T marks perfectly with a flashlight. In fact, when you get it close, you can use a semi-sharp flat-blade screwdriver in the "T" line to turn the motor just a bit to get it right on the T mark.
  • XR4DEZ
Posted December 05, 2005 - 08:48 PM
Yeah I've done it that way before too, but just find it easier when working alone to pop off the cover.Do you have a trick to line up the T and kick it at the same time? thanx
  • Desertskyy
Posted December 05, 2005 - 08:57 PM
Put the bike on a stand, Put it in 5th gear and rotate the rear tire.
Works for me.
  • AzMtnThumper
Posted December 05, 2005 - 09:30 PM
Yes, White Brudderz.
  • TimBrp
Posted December 06, 2005 - 03:49 AM
You must have the clamp on skid plate. I have the same setup. Loosen up your clamps and you should be able to remove the cover. It's tight but can be done. I like to pull the cover off as it makes it easier to see.
  • XR4DEZ
Posted December 06, 2005 - 10:45 AM
thanx guys
Fell Off Trailer by usafxr
  • Hot  43 replies
  • 9 replies
  • Hot  35 replies
  • Hot  186 replies
  • 22 replies
