oil pressure guage
4 replies to this topic
  • bork
Posted December 05, 2005 - 05:12 AM
Is there any place to hook up pressure guage ? I was wandering if it could tell how much wear on crank-rod bearing (or do they use rollers ?) Also pump weakness.
  • roadcam
Posted December 05, 2005 - 08:26 AM
I suppose you could easily tap into the oil lines, but to no real purpose ... Honda oil pump failures occur about as regularly as the Ice Ages .. :applause:
  • bork
Posted December 05, 2005 - 06:09 PM
What about crank to rod bearings ?
  • motomonte
Posted December 06, 2005 - 07:50 AM
I may not be sure off the location but for sure you could use a temperature gauge for the oil,since the hotter it gets the oils thins out.Anyways a press. gauge is a great idea.
  • SDBSKI
Posted December 06, 2005 - 09:02 PM
The crank uses roller needle bearing. The only accessable port would be the oil line to the valve train. You might be able to tee into the banjo fitting.
  • 4 replies
  • 3 replies
  • 22 replies
  • 17 replies
Honda XR650L 2017
  • 0 reviews
