Water Pump Shaft/Seal Photos
10 replies to this topic
  • TARFELE
Posted December 04, 2005 - 05:23 PM
Just replaced the seals and shaft in my 03's water pump. Indy gave me the parts list and if I would have ordered the numbers he gave me everything would have gone smooth, BUT, I didn't. Anyway I did it and if I can, anyone can.
Here are the part #'s and some photos to go along with it.
Parts to order:
#5GR-12458-00-00 SHAFT, IMPELLER
#93109-11073-00 OIL SEAL (water side seal)
#93102-12321-00 OIL SEAL (SD 12-22-5 HS)
#5TA-15462-00-00 GASKET, CRANKCASE COVER 3
I started by draining the coolant and taking off the header pipe.
http://i24.photobuck...240/SideAtt.jpg
http://i24.photobuck...a2240/Drain.jpg
Then removed the side case.
http://i24.photobuck...Sideremoved.jpg
Here is a photo of the outer water seal and impeller with the shaft already removed. The shaft just pulled out and the inner oil seal hammers out with a punch along with the bearing. The water seal popped out easy
http://i24.photobuck...0/Waterseal.jpg
Here is a photo of the bearing with shaft still in.
http://i24.photobuck...240/Bearing.jpg
Here are the groves that everyone keeps talking about wearing into the shaft. The old one is on the left and the new one is on the right(It will be obvious)
http://i24.photobuck...a2240/Shaft.jpg
I hope this helps somebody. I am a coward when it comes to this kind of stuff but it was easy.
  • drewpeacock
Posted December 04, 2005 - 05:36 PM
A few years back I installed the outer u-seal in backwards and it leaked like crazy. It took me three or four tries before I realized what I was doing wrong.
  • TARFELE
Posted December 04, 2005 - 05:56 PM
I had to make a few phone calls to make sure I had them in correctly. I found two threads in the search that talked about what dirrection they went in and they contradicted each other.
  • Indy_WR450
Posted December 04, 2005 - 07:03 PM
Good write up and pictures. :ride:
This is something that we all have to do once a year. :applause:
  • daveybobcat
Posted March 08, 2006 - 08:34 PM
Can anyone tell me then, which way this outer oil/water seal is placed? the links for the photorial no longer work so I dont know which way to put this thing in!
thanks everybody.
  • daveybobcat
Posted March 08, 2006 - 08:35 PM
so which way did you discover was the right way? by the time i got the part ordered, I forgot which way the thing was sitting in there.
thanks
  • unkle_george
Posted March 08, 2006 - 10:53 PM
Good write up and pictures. :thumbsup:
This is something that we all have to do once a year. :thumbsup:
How do I know if I need to do this? Will it start loosing water into the motor or just not pump as well?
  • TARFELE
Posted March 09, 2006 - 07:03 AM
thanks
Indy says that the spring side is away from the pressure.
Other people say spring side toward the pressure.
When I did mine I did not listen to Indy and I did mine with the springs toward the pressure. Well guess what!! It leaks when below 30 degrees. I have the new seals and pretty soon I am going to do it over again.
I am not sure which is correct so I will try both
  • TARFELE
Posted March 09, 2006 - 07:05 AM
You will get a drip out of the weap hole in the bottom of the water pump housing.
  • daveybobcat
Posted March 09, 2006 - 09:29 AM
Now that I have the part i Remember that the Spring side was FACING ME when i pulled it out. When you say "towards the pressure" , well which side has the pressure!?
  • TARFELE
Posted March 09, 2006 - 07:41 PM
Instead of saying pressure lets say towards the fluid.
