clutch perch
5 replies to this topic
  • baha
Posted December 04, 2005 - 10:56 AM
The stock clutch perch has a hole for the starter sensor. Now that I have broke the lever what options do I have- what is the best way to disconnect the sensor or is a aftermarket perch available that allows for the sensor to be used???
  • ARin
Posted December 05, 2005 - 03:08 AM
if you JUST broke the lever, replace the lever.
if the perch is broken, then you can replace with any old hot start clutch perch...but you will have to leave the sensor disconnected. unplug it from the harness...or clip and tape the wires.
I dont know of any aftermarket perches with the sensor hole.
  • jim-in-so-ore
Posted December 05, 2005 - 06:12 AM
When you clip the wires you have to solder the two wires into a loop or your bike will NOT start in gear. You will ALWAYS have to find neutral. This is a real pain in the butt after having primary start, where you just pull in the clutch, hit the button and go. Trust me, I've been there and done that.It aint no fun. :applause:
Jim
  • Bamster
Posted December 05, 2005 - 06:15 AM
and get some hand gaurds.
  • baha
Posted December 05, 2005 - 07:30 AM
Jim
Thats why I asked, even with hanguards a rock that was not smooth or flat I should say nailed it.. Thanks for the info and now I'm looking for stronger
as well as bit shorter unit
  • ARin
Posted December 05, 2005 - 04:27 PM
i stand corrected, yes you DO have to connect the wires...and that is what i had done.
