Need a Solution For Stiff Clutch / 05,WR450
13 replies to this topic
  • monkeynutz450
Posted December 02, 2005 - 08:14 AM
I know this has been brought up several times but I still have not seen a clear answer. I would like to know if there is an aftermarket product out there that would allow me to use just 2, fingers on my clutch lever. without killing my hand and forearm? Thanks in advance.
  • Indy_WR450
Posted December 02, 2005 - 10:20 AM
Rekluse Z-Start auto clutch! :applause:
  • mtrablue
Posted December 02, 2005 - 10:44 AM
if you mean, open a box, bolt it on and go, short of an auto clutch, there isn't one. it's just the mechanics of the stock clutch mechanism. leverage ratios, clutch spring, all that stuff. the wr450 even uses a different perch and blade from older 426's and yz's to improve it. it's still stiff.
get one of the cable oilers and keep it oiled. it helps more than most people think. from there your going to have to get creative. just remember, if you lengthen the actuating arm, your not going to get the same amount of clutch plate disengagement per amount of cable moved as before. as you clutch gets older, you might find you have a bit more clutch drag.
i now have a magura on my wr. is it easier? no. it just has a lot better action. it's smoother and more consistant. i put my finger on that lever and i know it's going to "feel" the same each time.
  • drewpeacock
Posted December 02, 2005 - 11:02 AM
One finger pull with the Rekluse. Another reason to love the Z-Start. :ride:
  • David37
Posted December 02, 2005 - 08:43 PM
Buy the Magura hydraulic clutch kit, it will reduce your clutch pull by 30% or more.
  • mtrablue
Posted December 03, 2005 - 07:45 PM
30% ! i don't think so. i just put one on a week ago. it's smoother and more predictable but not a lot (if any) easier.
  • tshe1
Posted December 03, 2005 - 10:17 PM
i have the MSR PREDATOR3 lever withe 3 anchor points.
  • slipnslide
Posted December 04, 2005 - 02:49 PM
I installed a the Moose clutch lever device that changes the lever ratio and it made big difference. It installs inline with the clutch cable, next to the lever. It has 3 settings/ratios to choose from. Compared to a friends KTM 520 hydraulic, it's much easier to pull and it does not create any clutch drag at all.
Slipnslide :applause:
  • Matty05
Posted December 04, 2005 - 05:39 PM
you can buy clutch leavers with a different pull ratio.
you can also cut and weld in a 10mm strip of metal to the clutch actuator arm.
  • wood5045
Posted December 04, 2005 - 06:52 PM
Go to your dealer and get a clutch actuator for a 98' WR400. It's 5mm longer than your's and saves you from having to cut and weld your current one. Just put one on my 06' YZ and it reduced the pull considerably. If you do a search there are a couple of articles on how to do it.
  • mtrablue
Posted December 04, 2005 - 08:48 PM
[quote name='mtrablue']if you mean, open a box, bolt it on and go, short of an auto clutch, there isn't one.
i stand corrected. looks like there are several after-market clutch levers that will help.
  • kelldog
Posted December 05, 2005 - 06:51 AM
Waaaaaaa!!! Don"t You Girls Have Any Hand Strengh ?
  • Matty05
Posted December 05, 2005 - 03:44 PM
If you took your bike out into the wild instead of ride it around the block and look cool in front of all the little kids, you would know that after hours of riding up and down gnarly hills can take it's toll on your forearms.
Maybe we should all wank more like you for more strength??? :applause:
  • WGP
Posted December 05, 2005 - 04:01 PM
The forearms are fine, but after 1 year of racing I have pain in two of my fingers and hand tendons from pulling that sucker in and slipping on climbs. :applause:
