locking up crank when doing valve adjust..
7 replies to this topic
  • yogist
Posted November 30, 2005 - 07:19 PM
Is there any way to lock up the crank when doing valve adjustments ??
I just did my first adjustment on my 01 426 and that was my only concern when working on it...
  • Ticeman
Posted November 30, 2005 - 07:24 PM
Why lock the crank up?
  • yogist
Posted November 30, 2005 - 07:25 PM
So you dont lose your timing mark??
  • Ticeman
Posted November 30, 2005 - 07:27 PM
Shouldn't be a problem, just turn it back to the mark if it goes off of it. I always leave my t-handle on the nut and notice the position on the t handle. If the motor turns, I turn it back.
  • yogist
Posted November 30, 2005 - 07:32 PM
I had an idea of an aluminum threaded rod ,with a piece of rubber on the end which would press up against the rotor and hold it still whilst working on it..
Threaded into the timing mark sight hole and pressed up against the rotor...
( just kinda thikin out loud)... I did my first valve adjust this weekend, and it seemed like there would be a way to hold it still....
Posted December 01, 2005 - 08:39 AM
It just really isn't necessary. :applause:
  • 426n520
Posted December 01, 2005 - 05:54 PM
Is it normal for lots of oil to pour out of the hole (bolt to turn crank)?
  • WheelsUp
Posted December 01, 2005 - 06:17 PM
If the engine has not been run in a couple of days, yes... all of your oil is in the crankcase.
If the engine has been run within the last few hours, most of the oil will be in the frame and very little (or none) will come out of the hole.
  • Hot  79 replies
  • Hot  35 replies
Is the 2016 GYTR Yamaha YZ450F too fast? by Fryboy
  • Hot  241 replies
  • Hot  33 replies
