Header Pipe
13 replies to this topic
  • THEHERDER
Posted November 30, 2005 - 06:33 AM
I dented up my header pipe real bad on my 04wr450f. I thought since everyone puts on new exhaust systems ebay and/or the classified section on this sight would be filled with my part. This is not the case, so, does anyone have the header pipe for sale on a 03 - 05 wr450f or 03 - 05 yz450f.
  • MathProf
Posted November 30, 2005 - 09:00 AM
Do search for "dented header' and believe what you read about "freezing out the dent".
  • Indy_WR450
Posted November 30, 2005 - 10:00 AM
Get a SS header next time. Stay away from TI since it heat cycle fatigues and then dents when a tiny pebble hits it! :applause:
  • Bamster
Posted November 30, 2005 - 11:57 AM
http://www.thumperta...&highlight=dent
If you want to get the dent out.
  • Motone82
Posted November 30, 2005 - 07:50 PM
Indy are you serious about the Ti denting? I just bought a Ti pipe and put it on last night. GREAT!!!!!
  • av8shunmeckaneck
Posted November 30, 2005 - 10:18 PM
Look for the header pipe off of a Yzf450, they are much cheaper.I had the same problem with my header pipe. Turns out the Yzf450 (quad) has the exact same bend and its not made of Ti. The only thing diff about it is the guard. It's a little shorter. I've been punishing mine for about a year now. Good luck with getting your fixed. Steve
  • ARin
Posted November 30, 2005 - 10:41 PM
now THAT is an intersting tidbit.
  • tshe1
Posted November 30, 2005 - 11:32 PM
i have ti header and it was hard dented.
i use the freezing method and you can see the results on "MY GARAGE".
i had to freeze it for more then 20 cycles, i assume it because titanium is more elastic then steel and i had a big dent in the pipe.
from cycle to cycle you barley can see the change, but it works!!! :applause:
  • 450high
Posted December 01, 2005 - 01:50 AM
I plugged one end the fitted by compressor hose to the other end.Heated it till the dent was red hot then gave it some air the the dent popped out let it cool for a minute than did again .I took a few goes now it's hard to find the dent.Mine was completely crushed in.I did not believe this was possible to repair .
  • Indy_WR450
Posted December 01, 2005 - 04:41 AM
You bet I went thru 4 stock Ti units before I figured it out! :ride: :applause:
  • BVille870
Posted December 01, 2005 - 07:56 PM
indy told me to go with ss and i haven't had any problems since. I went through 3 myself also. I bought a yamaha accesories header out of the delaer book for $125.
  • Indy_WR450
Posted December 01, 2005 - 08:02 PM
I know of at least 5 other WR's that experienced the same issues with the Ti header. Thanks for confirming your experience. :applause:
  • ARin
Posted December 01, 2005 - 08:37 PM
thats what THIS is for:
http://www.planetbla.../showtell/4.jpg
wraps pretty far around to the front of the pipe.
Got it on ebay, 35 bucks or something like that.
  • av8shunmeckaneck
Posted December 02, 2005 - 07:38 AM
I think a stock yzf450 stainless header costs about that much from the dealer too. I dont know what a "yamaha accessories header" is though. Maybe it's better, for about the same price.
