Chain Breaker!!
10 replies to this topic
  • pigryder
Posted November 29, 2005 - 04:19 PM
Hey guys I'm curious if you use a chain breaker to remove the chain can the same chain and link be used to put it back together? Never had a one piece chain before... :applause:
  • al_piv
Posted November 29, 2005 - 04:55 PM
Grinder and extra master links!
  • wr450fyamaha
Posted November 29, 2005 - 05:27 PM
youll need a master link bud.
  • pigryder
Posted December 01, 2005 - 12:41 PM
so after you break the chain you have to use a master link you cant press it back together into a one piece chain again?
  • don87xr600
Posted December 01, 2005 - 01:32 PM
Sure you can you just need this tool for $140.55
http://www.cycleshopusa.com/p1748.htm
  • craft
Posted December 01, 2005 - 02:04 PM
The best no doubt...Use a Dremel tool or buy a grinder bit for your drill and go to town on those pins. :applause:
  • knuklehead
Posted December 01, 2005 - 07:45 PM
With the right chain tool and a staked link you can make it just like it was stock
  • XR4DEZ
Posted December 01, 2005 - 09:20 PM
RK makes a good riveting tool that sells for about 60 bucks.I found one at a local dealer, works great. I use a grinder to break the chain.
  • pigryder
Posted December 02, 2005 - 04:42 PM
so basically a staked link which I can get at a shop? I figured I could grind out links like I used to on my cr125 when it would stretch chains (cheap ones) every ride. Grind off the pins, press in staked link with chain press...correct?
  • knuklehead
Posted December 02, 2005 - 08:16 PM
You press the link together than stake it to keep it from coming apart,lots of the high end chains come with a stake link, should be able to buy just the link also
  • pigryder
Posted December 03, 2005 - 05:22 AM
Thanks for the info guys!!!
Honda XR650L 2016
  • 0 reviews
  • 0 replies
  • 17 replies
  • 22 replies
Honda XR650L 2017
  • 0 reviews
