brake question?
7 replies to this topic
  • mose29
Posted November 27, 2005 - 08:06 PM
Does anyone know the size of the union bolt or banjo bolt on the back master for a 04 yz450.I hope its 10 or 12mm. :applause: thanks mose
  • yzf450jack
Posted November 27, 2005 - 08:16 PM
The threads are 10mm
  • John407
Posted November 27, 2005 - 08:54 PM
Isn't it a 12mm?
  • mose29
Posted November 28, 2005 - 05:05 AM
OK thats good.The reason I wanted to know is that I just got my rekluse in and decided that I wanted to try a left hand brake.I was thinking that I could use a clutch master I already have and run the hose to my back master and use a double hole banjo bolt and stack my hoses.Has anyone ever thought of this and is it possible?
  • Diode663
Posted November 28, 2005 - 06:46 AM
Why? I dont get it. You are going to have the front and rear brakes on the same lever? Sounds like disaster.
  • mose29
Posted November 28, 2005 - 02:22 PM
Left hand back brake.I no longer have a clutch lever.Rekluse has a kit that you can do the same thing for around $300.Just think going over a jump and pulling your left index finger to get the nose down.Sounds good to me.
  • Reyndogg
Posted November 28, 2005 - 03:36 PM
If it's a magura clutch, i dont think its a good idea as the fluid it has to use will not stand up to heat and iirc you cant use dot4 fluid in it....
if it's a street bike or other hydraulic clutch mc then yeah, it's possible to do I think - just need a really long brake line.
  • mose29
Posted November 28, 2005 - 04:05 PM
Im gonna give it shot.What the heck right?Just have to find that hose.
yz400f throttle bog by yz400fmaniac
  • Hot  28 replies
  • 0 replies
Is the 2016 GYTR Yamaha YZ450F too fast? by Fryboy
  • Hot  241 replies
  • Hot  36 replies
  • 5 replies
