Oil leak
8 replies to this topic
  • BergArabia
Posted November 26, 2005 - 08:35 PM
idiot does normal oil change.
next day oil puddle under the bike.
Nice new fresh oil so it is a leak.
doing the oil change I only removed the drain bolt at back of engine and the 8mm bolt and pipe connector on the side.
Checked the drain bolt it is OK.
So I suspect the pipe connector..
Actually I am sure the leak is where this connect meets the side of the engine. (saw little drops of oil there)
So I guess there is an o ring or something that is not properly in place?
Is the o-ring a consumable that I can easily collect from the yamaha parts?
Sorry for such a lame question but I want to fix this fast..
  • BergArabia
Posted November 26, 2005 - 09:09 PM
Well I will reply to my own lame post.
I found the Yamaha site.
They have a parts manual on line
I now have a photo and part number for the O ring that must be out of place..
Did a search on this site and found this..
http://www.yamaha-mo.../starthere.aspx
You can sign up on this site and view a parts catalog on-line..
Very nice...
  • rdefonce
Posted November 27, 2005 - 05:41 PM
BergArabia,
Good deal that you probably found the issue . . . and thanks for the tip about the helpful site. :applause:
  • maffud
Posted November 27, 2005 - 07:37 PM
Ha ha.. I just got my '03 YZ450F a few days ago. Yesterday, I changed the oil before riding it for the first time. After the ride (fortunately a short one) I noticed the same exact leak you found! I assumed it was an o-ring out of place or torn or something. I haven't opened it up yet to see what's up. Did you fix it already?
I am wondering how much of the oil will leak from that spot when it the metal hose is removed...?
I guess I'll head down to the local Yammie dealer for a new o-ring or two...
-Dan
  • BergArabia
Posted November 28, 2005 - 09:37 AM
Yeah I replaced the old o ring which was not torn but a bit compressed I guess.
The part number for the o-ring is 93210-10197
I paid about 75 cents per piece I bought a couple coz at that price it cost more to drive down to the Yamaha dealer than to buy the o-ring..
I think it is OK didn't see any more leaks lets see how it goes after a day or two.. Oh yeah I guess about 300 mls of oil came out when I removed the pipe to replace the o-ring so I had to top up too..
  • maffud
Posted November 28, 2005 - 05:31 PM
Thanks for the info. I'm off to check it out on my bike now.
-Dan
  • BergArabia
Posted November 29, 2005 - 05:50 AM
Nice and dry under the bike now so that was it.. :applause: Good luck with yours Dan..
Posted November 29, 2005 - 02:07 PM
Very nice...
There is no need to sign up for anything if you are averse to it. Just click "proceed to parts catalog".
  • BergArabia
Posted November 30, 2005 - 09:08 AM
Thanks Gray....
  • Hot  50 replies
  • 10 replies
  • Hot  36 replies
  • Hot  47 replies
  • Hot  38 replies
