Fuel screw--no affect
5 replies to this topic
  • dbailey223
Posted November 25, 2005 - 04:48 PM
I got a chance to ride today, so I got the bike warmed up after a 30 minute ride, then I decided to adjust the fuel screw. My recollection was that I was to screw it in until I noticed a change in the idling engine, then back it out a 1/2 turn.
Well, I turned it all the way in from 2 turns out with the bike idling, and no effect except possible the idle increasing a bit. My purpose in doing the adjustment was just o make sure that I didn't have it adjusted wrong. I can't complain much about bog, etc. since doing the JD kit, free mods, etc.
Was I doing the adjustment right?
  • bg10459
Posted November 25, 2005 - 05:51 PM
If you turned it all the way in (leaned the pilot circuit) without any effect, you probably need to go one step lower on the pilot jet. Try a 45 if you're currently running a 48 and see what happens.
BTW, to tune the screw, raise the idle to 1900 rpm, turn the screw all the way in and then back it out in 1/4 turn increments, allowing about 15 seconds at each step, until you get the best idle.
Are there any other symptoms? Or is it running OK?
  • dbailey223
Posted November 25, 2005 - 06:22 PM
It is running pretty well. I have to really hit the throttle from idle to experience a bog. And, it probably could use a bigger starter jet. So, I can't complain much!
FYI--I got a big performance increase with the PMB insert into the stock muffler. The other free mods didn't have much of an effect that I could notice.
So, for the fuel screw, I want to get the idle to 1900 rpm; then, turn the screw out 1/4 turns until I "get the best idle"? Can you explain what best idle is? Do you mean an increase in idle or smoother idle? Thanks!
  • Matty05
Posted November 25, 2005 - 06:52 PM
getting any backfiring when reving the engine?
I'd be checking for air leaks. A small air leak can cause all sorts of problems for your jetting.
  • bg10459
Posted November 25, 2005 - 09:12 PM
http://www.thumperfa.../fuel_screw.htm
Read through this page. There are a ton more like them in the FAQ at the top of the 250 forum too.
  • dbailey223
Posted November 25, 2005 - 11:07 PM
Thanks.
And nope, no backfiring or popping at all on deceleration or otherwise
